When loading paper in the Paper Tray set the paper type and size on the Control Panel before printing. NOTE: If [None] is selected in the Paper Type pull-down menu in the print driver, printing will default to the Control Panel settings. Printing will be performed only when the settings for the paper size and type configured in the print driver match the settings on the Control Panel. If the settings in the print driver and Control Panel do not match, follow the instructions displayed on the Control Panel. To select a paper type: NOTE: Paper type settings must match those of the actual paper loaded in the paper trays; otherwise, image quality problems can occur.
Press the [Menu] button on the Control Panel.
Press the [Up] or [Down] arrow button until 'Tray Settings' is selected on the Display Screen, and then press the [OK] button.
Press the [Up] or [Down] arrow button to select the tray, and then press the [OK] button.
Press the [Up] or [Down] arrow button until 'Paper Type' is selected, and then press the [OK] button.
Press the [Up] or [Down] arrow button to select the correct paper type for the loaded paper, and then press the [OK] button.
Press the [Menu] button to exit.
To select a paper size:
Press the [Up] or [Down] arrow button until 'Paper Size' is selected, and then press the [OK] button.
Press the [Up] or [Down] arrow button until the correct paper size is selected, and then press the [OK] button.
First you have to call you provoder for an unlock code. Then:
1 - Switch ON your Sony Ericsson W880i without any SIM Card, 2 - Press the left arrow key/button once, 3 - Press the button * twice, 4 - Press the left arrow key/button once, 5 - The message "Personalize with MNC2" will appear, (or you will have displayed an unlock menu, select the lock you want to unlock) 6 - Enter the Unlock Code.
If your Sony Ericsson W880i does not have a left arrow button/key(e.g. Sony Ericsson W950i) and on a few phones(not all) that have a "JOGDIAL" you must press the "down arrow" key/button instead of the "left arrow" key/button for step 2 & 4. We mean by "Down Arrow" to direct the Jogdial down! In the Sony Ericsson W950i and some other models, the down arrow button/key would be located on the side of the phone.
Yes there is a button to reverse the direction. Look right above the trigger in the middle of the drill you will see a oblong button with an arrow on it. Push it in. The button goes through the drill. On the other side the button will have the arrow pointing in the opposite direction. Push it. Happy Drilling !!
Make sure the left arrow key on the keyboard isn't stuck and then type. I suggest trying a new keyboard as well if that doesn't work- also pull off the left arrow cap entirely on the num pad and directional keys. If that doesn't work also try replacing the mouse in case it has a special button that is stuck.
see do some button has been stuck inside the calculator if it is stuck you should take it out by move in it because if some button is pressed you cannot push no other buttons
that means it is stuck on progressive scan. If your tv is not able to handle progressive scan, you need to change it back or reset the player.
The DVD player may be set to Progressive Scan Mode. You will need to change it to Video Mode by using the remote control. Point the remote control directly at the DVD player, and then press the PSCAN button 2-3 times. If you are still encountering problems with the DVD player, reset the unit back to the default setting.
To Reset,
Make sure you do not have a disk in the tray. Using the DVD player remote control:
1) Press the “Setup” button.
2) On the “Down” arrow, press it three times.
3) On the “Right’ arrow, press it once.
4) On the “Down” arrow, press it three times.
5) On the “Right” arrow, press it once, then press “Enter”.
6) Press the Setup button.
*The default setting will take affect as soon as you press the setup button (step 6).
Hope it helps..please rate!
it seems your start button might be stuck: the start button acts as a "ditch game" button in home games: hold it for about 5 seconds and then the failed screen will show.
I would suggest purchasing another dance pad, or trying to see if you can, by pressing the area gently "unstick" the start button area.
Simple! Read warnings carefully! It said "remove lens cap and press SET button"! So remove the lens cap and then press the SET button (or arrow downward in the four directions button)! You don´t need to RESET anything...
