20 Most Recent Coby DVD-224 DVD Player Questions & Answers
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately, Coby is a company whose electronics cannot be controlled by any remote other than the one that came with it. This means there is no code available for universal remotes. If you need a replacement remote (it will be identical to the one that came with the unit) please call our customer service number above. They will take your information and provide you with the procedure for ordering a part from Coby.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Coby DVD-224 DVD... | Answered on May 19, 2018
http://www.dvddemystifiziert.de/codefree_en/coby.html
Unfortunately, I don't see Coby 206. There is a 207 however if that would work.
Unlock Coby DVD players - DVD hack
Coby DVD-201 / DVD-217 / DVD-224 / DVD-227 / DVD-237 / DVD-505 / DVD-514 / DVD-527
  1. Press SETUP
  2. Press VOL+, VOL-, VOL+, VOL-
  3. Current RC should be displayed
  4. Select the RC with RIGHT and LEFT (255=Codefree)
  5. Press SETUP
  6. Turn the player off
Coby DVD-202 / DVD-203 / DVD-207 / DVD-208 / DVD-218 / DVD-507 / DVD-508 / DVD-606 / DVD-615
  1. Method 1:
  2. Press SETUP
  3. Press 2, 1, 8, 8
  4. A new menu entry appears (Version)
  5. Select it
  6. Press ENTER
  7. Select "Region" with RIGHT
  8. Select RC with UP, DOWN (0 = codefree)
  9. Press SETUP
  10. Turn the player off
  1. Method 2:
  2. Press SETUP
  3. Press VOL+, VOL-, VOL+, VOL-
  4. Current RC should be displayed
  5. Select the RC with RIGHT and LEFT (255=Codefree)
  6. Press SETUP
  7. Turn the player off
Coby DVD-224 DVD... | Answered on Feb 08, 2018
Quisas. Only if the control frequencies for both units are identical. Since you are dealing with same manufacturer you have a better chance of it working than if you were using two units from different manufacturers.
Coby DVD-224 DVD... | Answered on Mar 21, 2015
Sometimes some of the touchpad buttons (just a plastic membrane inside the remote) corroded and won't work. Have you replaced the batteries?
Coby DVD-224 DVD... | Answered on Feb 19, 2015
I hope this helps
You need an OneForAll6 remote (URC 7560)
  1. Press DVD device button (set remote to DVD)
  2. Press and hold MAGIC until it flashes 2x
  3. Enter Setup Code (0539)
  4. Press MAGIC again
  5. Enter 085
  6. Enter 222 222 005 255
  7. (should be displayed)
  8. Press PLAY
Coby DVD-224 DVD... | Answered on Jun 13, 2014
You can not use it manually, either! I will never buy another Coby!
Coby DVD-224 DVD... | Answered on Apr 02, 2014
Just about any universal remote from any store will work with this
Coby DVD-224 DVD... | Answered on Jan 10, 2014
Check to see if anythig is blocking the tray from opening. Also the tray motor or connections may be failing. I would open the case, remove and replace as many connections, one at a time, to make sure the connections were good. If the tray still does not move, then one or more than one component has failed. It could be an electronic component or the motor.
Coby DVD-224 DVD... | Answered on Jul 06, 2013
please be specific of what dvd do you have. if a camcorder dvd, it must be finalized buy the camcorder you recorded on.
Coby DVD-224 DVD... | Answered on Dec 02, 2012
The lazer is not reading the disc any more,It is hooche.End to get it repair will cost you more ,Then to just go out end buy a new one.The repair can range from $125 to $250, Deprending on what brand it is.
Coby DVD-224 DVD... | Answered on Oct 18, 2012
I work for Memorex technical support. Our customer service phone number is 1-800-919-3647.
On the back of your player you should see a switch that can slide back and forth that's marked PSCAN. Slide the switch into the opposite position from which it's in now. The should solve your problem.
Coby DVD-224 DVD... | Answered on Oct 14, 2012
Coby DVD-224 DVD Player Logo
168 questions posted
Top Coby Televison & Video Experts
Ekse
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Coby Televison & Video
Most Popular Question
coby dvd 224 need correct code phillips
  • Televison & Video
