My OS is Win XP Professional. My computer is a Dell Inspiron 8600 with an Intel Pentium M processor operating at 1500 MHZ. I have !GB Ram.
When I click on the Shut Down command, my computer takes approximately one minute to shutdown. Is there anything I can do to reduce the time?My OS is Win XP Professional. My computer is a Dell Inspiron 8600 with an Intel Pentium M processor operating at 1500 MHZ. I have !GB Ram.
You can't post conmments that contain an email address.
Start Registry Editor and navigate to the following key: [HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management] Set ClearPageFileAtShutdown value to 0
Or, using Group Policy Editor [for Windows XP Professional] Click Start, Run and type Secpol.msc Click Local Policies | Security Options In the right-pane, set Shutdown: Clear virtual memory pagefile to Disabled However, this setting is not the only cause for slow shutdowns. Non-responsive programs and Services also contribute to slow shutdowns. If the problem is seen recently after installing a third-party driver or software, try a System Restore rollback to see if that resolves the slow shutdown problem.
There are a number of reasons that may causing your HP computer running slow to shut down or start up, but generally two factors: outdated hardware or poor system maintenance. For hardware part: you can get more RAM, higher CPU etc. For system part: there might be a lot of junk files, caches, errors etc out there, about 80% slow HP issues are caused by this reason, in this case you can rely on http://www.speeduphp.com/ to free detect and fix related issues. Regards!
Tip #1: Cut down of the programs and processes running in the background.--When you start your computer many unnecessary processes are loaded. You can eliminate this by managing your msconfig.
Here is how: 1. Open your Start menu. 2. Click Run 3. In the command screen type "msconfig.exe" 4. In the system configuration utility,click either service or startup tab. 5. Uncheck all programs that your are no longer want to run in the background. 6. Click OK
Tip #2: Defrag your Computer--The faster your computer can find
files the quicker it can shutdown. A very slow computer shutdown can
be the result of your hard drive trying to search for disorganized and
fragmented files that it needs for shutdown . Organize your hard drive
by performing a defragmentation. Here is how: 1. Open the Start Menu 2. Click on My Computer 3. Right Click your C: drive or your hard drive image. 4. Scroll down to the Properties and Click 5. In the Properties Menus, Open the Tools menu. 6. Choose Defragment Now. 7. In the Disk Deframenter menu. Click on Defragment
Tip #3: Clean your Registry- Usually slow computer shutdown often occurs due to a corrupted registry. You should perform a registry clean, use RegInOut to fix this issue instantly.
Hi, Try to check-up control panel of your PC, I know your PC configured for automatic windows application update. also try to full scan(present anti-virus software) your PC system maybe same spyware, worms and virus inside on the operating system (OS) and other software desktop. Please see screen shot picture below.
The most common reason of a PC getting auto shutdown is that the processor may be getting over heated. Every processor has a TjMax temperature. when the processor reaches that temperature, it starts throttling(slow down) and if it continues to become more hotter then it automatically sends a shutdown signal to the Computer
Solution:-
Clean the Heat-sink.
Check the fan speed.
clean the cabinet.
use thermal paste over thee processor.
Make sure there is proper ventilation in your cabinet.
When you shutdown your Windows XP computer, it may take more time to complete the shutdown process. Slow shutdowns are caused by a number of factors. One of the common cause is the Clear Pagefile at Shutdown option enabled.
Some points to improve the shutdown times:
Follow these steps to open registry editor.
Click on start and the click on run
In run dialog box type regedit
Either press enter or click Ok button on the run dialog
the same thing happened to me this is not a device error but a OS error to solve this problem use system restore to restore the system to a date before this error started occurring this a totally random error that happens due to a code fault just restore the system to a date where this problem was not there and you will be fine
