I have followed all instructions from manual about correcting flashing arrow alert: No paper jam, reconnecting printer without going thru surge protector, etc., etc.
Printer worked fine til I replaced the color cartridge (hp 57). Since then printer has not worked and arrow won't stop flashing yellow.
Printer about 4 years old and this is my first problem. Help?
SOURCE: Colour won't print - HP Deskjet 5150 Inkjet Printe
hi, remove the color cartg take a tissue paper and run it horizontaly on the nozzel, if u can notice the three colors, ur cartridge is ok, may be the contact area of the cartridge,try to clean both the surfaces, and install the exact driver for the printer which will give you the cartridge maintenence options. let me know??
SOURCE: HP psc 1350 HP 57 print cartridge
Same problem with me.
So:
I openede the whole box ( 4 screws ) in the corners. Then I presed the tiny belt on the left side to its socket, cleaned the contacts of the cartridges (56,57) with water and made them dry.
Then I reched the position of the small door which is ment to be opened once you wnat to replace the cartridge.
After this the printer works again.
SOURCE: How to check ink levels on deskjet 5150?
Download the instruction Manual for the HP deskjet, model 5150:
http://h10025.www1.hp.com/ewfrf/wc/product?product=304431&lc=en&cc=us&dlc=en&submit.y=4&submit.x=7〈=en&cc=us
SOURCE: HP photosmart C4480 printer cartridge incompatible error BEWARE SPAM NUMBER BELOW 1-800-532-4187
Well....I solved the problem......bought a new Canon printer!!
I tried everything...unplugging, cleaning everything that was mentioned above. I was onto HP online support several time, but they were absolutely no help at all...they basically told me that the cartridge must be damaged or ink dried up and to buy a new cartridge to see if the error persisted.....I don't think so!!!
I will never by HP again after having issues with the last two I have had. I love my new Canon printer it is EVERYTHING that HP wasnt.
same as above
I have the same problem
I have a similar problem.and tried everything the troublshooting questions
asked me to do. but my printer will not turn off nor print.I have to unplug it.to turn it off. by the way all of my lights are flashing.
if you haven't been to troubleshooting function of the printer.
I think u can find it in hp printer assistant under maintenance.
thanks
linda
