Coffee Makers & Espresso Machines Logo
mark warfield Posted on Dec 21, 2011
BSC can repair anything all fully trained [email protected] postal service too.email any problems you have...
Hi i repair all brands and makes of domestic appliances... if you have a problem give me a email or call 07779933829..uk based. postal service too all over uk
2 Related Answers
Anonymous
  • Posted on Jul 23, 2009
SOURCE: If you need a Franke trained coffee machine engineer
Hi
I have just bought a Franke Flair coffee machine second hand. It looks like new and the seller said it was in good working order - however it does not have the grinder blocker and I think we need one. I wouldn't mind also getting the once over from an expert and then maybe some kind of ongoing contact should we have problems with it. What are your rates?
Anonymous
  • Posted on Oct 28, 2011
Im in nuneaton how much is the cost of a servies for the machine?
Fisher & Paykel ActiveSmart 517L Top Freezer E521TRX3 control panel lights blinking
Hello Ajay Gaddi...
Flashing panel...
I got NOTHING after reading several manuals
(seems to be a UK model... We have limited information here in the USA)...
Accept my apology and try these references
(as appropriate)
If after checking these points you still need assistance, please refer to your nearest
Fisher & Paykel Authorised Repairer, or contact us through our local website listed on the back cover.
In New Zealand if you need assistance...*
Call your Fisher & Paykel retailer who is trained to provide information on your appliance, or if we
can be of any further help, please contact our Customer Care Centre.
Toll Free: 0800 FP CARE or 0800 37 2273
Fax: (09) 273 0656
Email: [email protected]
Postal address: Fisher & Paykel Appliances Ltd, PO Box 58732, Botany, Manukau 2163, Auckland.
If you need service...*
Fisher & Paykel has a network of independent Fisher & Paykel Authorised Repairers whose fully
trained technicians can carry out any service necessary on your appliance. Your dealer or our
Customer Care Centre can recommend a Fisher & Paykel Authorised Repairer in your area.
In Australia if you need assistance...*
Call the Fisher & Paykel Customer Care Centre and talk to one of our Customer Care Consultants.
Toll Free: 1300 650 590
Fax: (07) 3826 9298
Postal address: Fisher & Paykel Appliances Ltd, P.O. Box 798, Cleveland, QLD 4163
Fisher & Paykel has a network of qualified Fisher & Paykel Authorised Repairers responsible for
servicing only Fisher & Paykel branded appliances. Our Customer Care Centre can recommend a
qualified Fisher & Paykel Authorised Repairer in your area.
In United Kingdom if you need assistance...*
Phone: (0845) 066 2200
Fax: (0845) 331 2360
Postal address: Fisher & Paykel Appliances Ltd, Maidstone Road, Kingston, Milton Keynes,
Buckinghamshire, MK10 0BD
Hello! on the screen it appears "Fill beans
hi you need the grinder stripped and serviced .. or might need new grinder... bsc appliances 07779933829 we have a postal service to repair too.
Descaling takes too long
hi it should take approx 10 min .... if not you may have a problem with boiler .. bsc appliances 07779933829 we also have a postal service .. anywere.
Magnifier doesn't get enough steam to warm milk or froth milk
sounds like you need it stripped down and serviced ... bsc appliances bristol 07779933829 postal service too.fully trained by delonghi.
Warning triangle on can not get it to go off
hi sounds like you have pcb problem ... u need it tested ...bsc appliances bristol 07779933829 postal service too...
1helpful
NO WATER GETTING THROUGH FROM RESERVOIR
trun unit on let it setup .... fill water up ....let it heat up until ready ....when it trys to flush through turn the steam valve open fully... pump will then clear air lock ...when it sounds quieter turn steam off...job done. bsc appliances 07779933829 postal service too.
Hi i have that machine delonghi magnifica suddenly the excalmation mark light starts what is the reason
itr could need descale ...or you have a problem with the pcb or motor .... make sure bucket is in correctly and door is shut prop... bsc appliances 07779933829 postal service too.
The machine is making strange noises when grinding
when first started up turn the steam valve open to get out air ... job done i hope or you need it repaired ... bsc appliances 07779933829 we repair via postal service anywere .
Top DeLonghi Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Kolbrun...
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
