If both the RED brake light and the ABS light are coming on while you are driving the car, you either have an hydraulic failure or there is a problem with your ABS module that can potentially affect your regular service brakes.
The first thing to do would be to check the fluid level in your brake master cylinder. If it is low, you need to find out WHY. There is always a reason for the fluid level to be low. It is NOT SAFE to just add fluid without correcting the problem that caused the fluid level to be low.
If the fluid level is OK, then you must scan your antilock brake module for fault codes. The antilock brake module controls the antilock light and can affect the RED brake light as well. There are many different possible failures that can cause this. There is NO OTHER WAY to know why the antilock module has turned the light on. You can spin your wheels for days, replace a BUNCH of parts and never find the problem if you do not scan the module first.
It generally occurs while using the cruise control. The brake/abs lights come on and the
cruise drops out. You can reset the cruise but the brake/abs lights stay on.
Also, the odometer no longer records mileage while the lights are on.
I
found that, by pushing on the connector at the abs unit under the hood, the
problem will disappear and the lights will go out. The next time cruise is used,
the lights will reappear after a short time.
ABS LIGHT AND MODULE TROUBLESHOOTING:
Anti
lock brake system light comes up when there is issue with car brake systems. It
can be low brake fluid or faulty ABS fuse or its issue with brake system or assembly.
Your vehicles brake system needs inspection.
To
troubleshoot these issues, I suggest you to refer the help links provided below.
There are direct links with accurate solution, for these specific issues.
Click
the link below and follow the procedure: ------
http://howtobyme.blogspot.com/2011/11/abs-and-service-light-comes-on.html
http://howtobyme.blogspot.com/2011/11/abs-light-stays-on-but-brakes-work-fine.html
http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
http://whoisbyme.blogspot.in/2012/07/battery-light-and-abs-light-on-dash.html
http://technoanswers.blogspot.com/2011/11/how-anti-lock-brakes-work.html
http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html
http://technoanswers.blogspot.com/2012/01/anti-lock-brake-light-stays-on-all-time.html
ABS
light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
http://technoanswers.blogspot.in/2012/05/2008-toyota-highlander-abs-warning.html
http://technoanswers.blogspot.in/2012/04/2003-lexus-es-vsc-trac-off-abs-lights.html
http://technoanswers.blogspot.in/2012/04/2008-toyota-highlander-hybrid-warning.html
http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
http://schematicsdiagram.blogspot.in/2012/02/can-i-drive-car-without-abs-fuse.html
http://schematicsdiagram.blogspot.com/2011/12/where-is-abstcs-module-located-on-2005.html
http://schematicsdiagram.blogspot.com/2012/01/abs-motor-keeps-running.html
http://howtobyme.blogspot.com/2011/12/when-car-stopsabs-pump-turns-on.html
http://technoanswers.blogspot.in/2012/02/replacing-abs-unit-on-buick-century.html
http://technoanswers.blogspot.in/2012/04/toyota-camry-premature-abs-actuation.html
How to replace ABS Modulator Control
Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-modulator-control.html
How to replace ABS Pump Assembly on
Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-pump-assembly-on.html
How to remove ABS Accumulator on
Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-accumulator-on-acura.html
How to remove ABS Control Unit on
Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-control-unit-on-acura.html
These details will help.
Thanks.
ABS light stays on but brakes work fine?
VCS and ABS lights go on and off
intermittently on Lexus?
http://howtobyme.blogspot.com/2011/11/vcs-and-abs-lights-go-on-and-off.html
The ABS and Traction
Control Lights stays ON dash of car?
ABS & Brake lights warning indicator
steady on dash and speedometer not working for Dodge Ram?
Battery
Light and ABS Light on Dash
Sometimes ABS light comes on while
Driving?
http://howtobyme.blogspot.com/2011/12/sometimes-abs-light-comes-on-while.html
How Anti-Lock Brakes Work?
Brake System Troubleshooting?
Anti-lock brake light stays on all the time?
ABS light comes on and Car makes
Grinding noise?
ABS trouble codes for all models?
2008 Toyota Highlander: ABS warning light Blinking and OBD Error
codes Coming?
2003 Lexus ES: VSC, TRAC OFF, ABS lights ON?
2008 Toyota Highlander Hybrid: Warning Lights Abs, Vsc & Brake
Are On?
ABS & Brake warning lights remains steady
on dash?
Can I drive the car without ABS fuse
connected?
Where is ABS/TCS module located on 2005
Cadillac Deville
ABS motor keeps running?
When the car stops, abs pump turns ON?
Replacing ABS unit on Buick Century?
2008 Toyota Tacoma: ABS causes Brake pedal fade?
http://technoanswers.blogspot.in/2012/04/2008-toyota-tacoma-abs-causes-brake.html
Toyota Camry: Premature ABS Actuation?
Acura Integra?
Acura Integra?
Acura Integra?
Thanks.
