SOURCE: How do ichange the time on Panasonic KX-T7431??
How do I change the display names for each extention name on my KX-T7431 panasonic corded phone?
SOURCE: Voicemail
The answer for both of you is the System Administrator's mailbox. It lets you addl, delete and edit mailboxes and reset passwords.
When your system was installed, you should have been given instructions and passwords for both the Message Manager and System Manager's mailboxes. The access to those boxes is similar and I will not give out that sequence in a public forum, but you should be able to find it in the manual or via email to me...I'll show up on the web somewhere.
Carl
SOURCE: help how to set-up a voicemail on panasonic
CLICK HERE for your owners manual in PDF format.
This phone does not have voicemail capabilities. Your company's voicemail system is seperate.
You can find Voivemail notification settings on page 10 of the manual.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: How do I put the answering machine on my Panasonic KX-T7431?
For both of you, the answer isn't easy....unless it's already set up in the sytsem and you just have to dial the magic number :-)
Depending on how it was installed, the Pana TD system has either automatic or manual switching to DAY/NIGHT mode. If your NIGHT program is set up to send calls to voice mail, you can just put the system in nights by dialing 781 on the intercom, and I think in a TD you can do that from any phone. 780 returns it to days. IIRC the * button on a idle display phone will tell you what mode the system is in, as well as when you dial the 78x codes, it will beep once if it changes or twice if it was already in that mode.
If none of this works, or you already have Auto D/N switching set up and it doesn't or never worked, it's going to require some system programming. Your friendly Pana installer will be happy to do that for you.
Carl
SOURCE: need to access voicemail with no password-panasonic KX-T230 phone
Find the password to mailbox 999 or call a Panasonic dealer.
Carl
