HP Pavilion dv9720us Notebook Logo
Anthony Posted on Nov 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ACPI\HPQ0007\2&DABA3FF&0
Level 3:
  • HP Master 17,130 Answers
  • Posted on Nov 30, 2011
HP Master
Level 3:
Answers
17130
Questions
0
Helped
3635788
Points
52372
Please mention the nature of the fault that is seen on the PC, for support log on to :
http://www8.hp.com/uk/en/support-drivers.html
1 Related Answer
Anonymous
  • 62 Answers
  • Posted on Sep 08, 2009
SOURCE: ACPI\HPQ0007\2&DABA3FF&0
what is the problem u had
1helpful
2answers
ACPI\ASD0001\2&DABA3FF&1
that is the "Quick Launch Buttons" driver.
Check the HP Support site for your exact Model and download it.
if that fails, see if the solutions on this page work.
Unknown device ACPI HPQ0006 2 DABA3FF 1 HP Enterprise Business Community
I have a windows media center edition 2005 edition pc that had a new hdd installed and OS, programs, drivers, etc loaded up. Its an HP m7674n desk top. The issue is that I'm still missing one driver -...
I have the same issue but with 7250n, I have not found a solution yet. ASUS P5LP-LE , p4 2.8, 1g RAM, ASUS video card. [email protected]
do you think it is worth $ to get recovery disk from HP?
4helpful
1helpful
ACPI is not a compliant
Enter you bios & disable ACPI. Restart the system. Than update your windows. There should be an update for ACPI through Microsoft update service. Once installed restart your system & enter into your bios. Now enable ACPI. Save & exit the bios.
If this does not help you can try the work around found on Microsoft's web site. See the link provided;
http://support.microsoft.com/kb/314830
Cheers
Mike
24helpful
3answers
Microsoft ACPI-Compliant Embedded Controller driver
Microsoft downloads and type in Microsoft ACPI-Compliant Embedded Controller driver or IBM Lenuvo site for this driver.
I need to disable tha acpi on an acer travelmate 529tx but i don't know how to do it. i am trying to install xp after a failure. i get bsod and says to press f7 when i install storage drivers but i need a...
I have seen on many forums that ACPI makes a lot of troubles to a lot of users under Windows. I will try to explain several things about ACPI and I hope that you will be able to solve your problems after you read this article. I cover only most encountered issues, but always there is a choice even if it's called ACPI disable.:)
The computer ACPI support is detected in the setup stage, but there are less frequent cases when ACPI is not detected and the Standard PC HAL is installed. If you want to force the installation of the ACPI HAL:
1. At the blue screen of the Windows XP setup when it prompts you to press F6 for additional mass storage devices press F5 and you will have a list of options.
2. Choose the proper HAL for your machine remembering that there are also different HALs for multiprocessor machines.
3. Complete the setup, go to Setup / Control Panel / System / Hardware / Device Manager / Computer. If you have listed the Advanced configuration and Power Management (ACPI) the process was completed successfully.
Warning: You can do the same thing if you don't want to install ACPI and your BIOS doesn't support ACPI disable setting. Just choose the Standard Computer HAL from the list of options.
Another method to disable ACPI is:
  • wait for the text-phase of XP setup to complete
  • before XP Setup Wizard to load, boot into DOS and change ACPIEnable = 0 from ACPIEnable = 1 in file c:\txtsetup.sif
The reason why ACPI is not installed on a computer with known ACPI compatibility may be a Microsoft known subtle incompatibility which can lead to hardware instability. In the installation step Windows XP checks the BIOS compatibility with ACPI and the BIOS presence on a known bad list. If the BIOS is there ACPI is not installed. Of course than errors can occur so you can force the ACPI installation (not recommended).
Try disabling it in the BIOS first, this can not be done on a computer with the operating system already installed as it will cause the machine to stop. MUST be done when you initially install the OPERATING SYSTEM.
Regards.
1helpful
2answers
Does the following show any deficiency with the mother board?
Hello there.
As the errors say, there are no drivers installed to make the motherboard function correctly. Your Windows Operating System only knows so many drivers. So what i recommend is to download and install the drivers for your motherboard.
For Windows XP professional click here
The drivers you need on that page are as follows, please install them in this order as well or it may not work correctly.
document.write("Chipset: Intel® Chipset Software Installation Utility for Intel® Desktop Boards")* Chipset: Intel® Chipset Software Installation Utility for Intel® Desktop Boards (1342KB)
* Video: Intel® Extreme Graphics Driver (5410KB)
* LAN: Intel LAN [V6.4_PRO2KXP_ONLY.EXE] (8798KB)
* Audio: Realtek AC97 [AUD_ALLOS_5.10.0.6020_PV_REALTEKAC97.EXE] (24333KB)
* USB: USB 2.0 [USB2.0.EXE] (1106KB)
This will install the drivers for your Chipset, Video, Network, Audio and USB.
Afterwards everything should appear as installed in device manager.
Hope this helps.
2helpful
5answers
Wireless card not functioning/disabled after loading XP in a Compaq Presario C700T CTO Notebook PC
The wireless is not going to turn on and off via the switch properly until we get the drivers loaded to make it work. There are 3 possible types of wireless card it could be, so we have to find out the exact model number of your system. On the bottom there should be a label that has a P/N or part number listed. what are those numbers. Here's an example of the label:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00033108&lc=en&cc=us&lang=en&os=2093&product=3632144&dlc=en
or
http://tinyurl.com/35dt4h
we need the info listed for #1, #2 and #3. Then we should be able to determine which adapter you have, and then we can (hopefully) find some Windows XP drivers for you.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
