Hi there:
This code is related to the TCC circuit in the transmission. It is
either stuck in the closed position (regulator valve, or control valve)
or it has a bad torque converter. You will need to take it to a
reputable transmission shop to have some fluid line pressure tests done.
The cost of course will depend on the repair needed. Some parts of the
repair for this are pretty simple and only require removal of the oil
pan and valve body to access related parts, but if the converter has
ballooned and needs to be replaced the transmission will need to come
out for repairs. Most good shops are happy to give you a free written
estimate, ask for one before you authorize any repair work. Could be
rather simple, but could just as easily be complex, hard to tell from
where I'm setting. Better to have it tested than to just start throwing
expensive parts at it in an attempt to fix it. Most of these failures
are caused by dirt, and things getting plugged up due to lack of
maintenance.
Honda Service News November 2003 TITLE:
A/T DTC P0740, P0741 Repair Tips: Another Look APPLIES TO:
All Models
SERVICE TIP:
If
you're doing a repair for DTC P0740 or P0741 (lock-up control system)
on any Honda models with A/T, except Passport, refer to this table
first:
If
there is no S/B posted on ISIS for the vehicle you're working on, go to
the DTC P0740 or P0741 troubleshooting procedure in the Automatic
Transmission section of the appropriate S/M or under DTC Troubleshooting
in ISIS. If the procedure recommends replacing the A/T, make sure you
have a reman A/T on hand. Remove the original A/T, and look at the
condition of the torque converter O-ring. Then follow these tips to
ensure a lasting repair.
Missing or cut O-ring . If the O-ring is
missing or cut, the ATF can leak internally, causing DTC P0740 or P0741
to set. Replace the O-ring, and reuse the original A/T. Make sure the
problem has been fixed by connecting the HDS and testdriving the vehicle
using the previous DTC P0740 or P0741 freeze data parameters (match the
TPS and VSS values for at least 25 seconds ). If the DTC comes back,
install the reman A/T. If the DTC doesn't come back, return the reman
A/T to the reman center.
Flattened or deformed O-ring . If the
O-ring is flattened or deformed, replace the A/T. The O-ring can get
damaged if the ATF pump seizes up and overheats. Make sure the problem
has been fixed by connecting the HDS and testdriving the vehicle using
the previous DTC P0740 or P0741 freeze data parameters (match the TPS
O-ring is OK . If the
O-ring is round and in good condition, the most likely cause for DTC
P0740 or P0741 to set is the A/T, the torque converter, or both. Install
the reman A/T. Make sure the problem has been fixed by connecting the
HDS and test-driving the vehicle using the previous DTC P0740 or P0741
freeze data parameters (match the TPS and VSS values for 25 seconds ).
Before you install the reman A/T, make sure the O-ring on the torque
converter is properly installed.
Hope this helps; also keep in mind that your feedback
is important and
I`ll appreciate your time and consideration if you leave some
testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
