Jenn-Air JCD2389G Side by Side Refrigerator Logo
Posted on Sep 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Intermittant noise I have had my fridge for one month and it's very noisy. Every half hour or so it makes a loud buzzing noise that lasts for about 1-3 minutes. It seems to be coming from the right side of the fridge and the ice maker is fine. thanks for your help
  • cpiez Sep 23, 2008
    I have same problem - except that it's a six year old refrigerator (Jenn-Air JCD2389G). A couple months after the noise started, the refrig slowly functioned less well. Cooling side curdled the milk first, then frost started in the freezer. Dealer replaced a heater & thermal assembly (2 visits w/ all day wait, diagnostic fee plus parts fee) and it worked for a month and then the noise started again and the failure cycle repeated. Dealer replaced heater & thermal assembly again, claimed that noise was ice maker. (It's not, I even asked a friend to listen to it - he said "that's not normal"). It worked for a month and then noise returned: failure cycle repeated third time. I don't trust the dealer anymore ... came to this site looking for new ideas.
  • deahsch Sep 27, 2008
    we had the installer come and check the valves and installation he also adjusted the leveling of the fridge and the problem while not completely eradicated is much much better, i think it has to do with the slope in my kitchen floor. Thanks!
john gagnon
Level 3:
  • Master 943 Answers
  • Posted on Sep 27, 2008
john gagnon
Master
Level 3:
Answers
943
Questions
Helped
324254
Points
2163
Hi thanks for the question that buzzing noise is probably coming from the ice maker water valve that's about the time it cycles i would not worry about its fine just a little noise thanks the appliance doc but if it s too noisy replace the water valve
Our refrigerator does a very loud buzzing for 5 seconds 3 or 4 times a day what is the problem its only 3 months old and very annoying
Normally as loud buzzing from the fridge on that frequency it just the icemaker cycling, the water inlet solenoid valve often makes a buzzing noise depending upon water pressure. Other than the noise, there is nothing to worry about.
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Loud buzzing noise
Yes that is your relay they are pretty common use your model number to track one down may tag is owned by whirlpool so most local places will have them
2helpful
Whirlpool fridge incessant buzzing
The knocking noise when cuts off , is a compressor internal motor support spring , broken . This does not mean the compressor is bad , only noisy for the rest of the compressor life , but should be covered under the 5 yr warranty . The gurgling sound is the refrigerant being pumped thru the system . The buzzing could be from the compressor also . My suggestion , would be to call a factory warranty company , to see if they can replace the compressor under warranty .
3answers
Noisy Fan
we had the same problems. Made awful sounds and was very loud. We finally had to replace the fan at the cost of $230. sorry! better to replace it now than to lose all of your food
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Loud periodic buzzing
Are you sure this noise is not just the ice maker trying to cycle without water? If it is not turned off it will dry cycle every 15 min or so.
Top Jenn-Air Refrigerators Experts
john h
ZJ Limited
ZJ Limited
Jose Ramirez
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
