Hi doug c197...
I will also include a fuel routing drawing.
Before you remove any fuel lines, make a drawing or take a picture of how the lines are connected to the tank for later reference.
You will need to remove all the old fuel lines and fuel filter out of the gas tank.
After you have all the fuel lines and filter removed.
You need a piece of wire...smaller diameter than the inside of the fuel line, insert the wire into the fuel line until it exits the fuel line then bend a hook on the end of the wire to hook over the fuel line.
You will lubricate about 1 inch of fuel line with a small amount of vasoline or light machine oil...
Now using your fingers or small needle nose pliers collapse the fuel line around the wire hook and insert it into the hole in the fuel tank.
After you have the fuel line in the tank, extend enough fuel line into the tank to exit the fill spout of the tank and remove the wire from the fuel line.
You will insert the new or cleaned fuel filter into the line and pull the fuel line to pull the filter just back into the tank.
Please take time to rate me
