20 Most Recent John Deere J3816 Chaninsaw Switch Questions & Answers
Some just connect externally to a barb fitting, but usually the fuel line and filter are all one piece. They are a bear to remove and replace because most of the new saws have a built in grommet in the fuel line itself to seal the plastic tank hole as it passes through it. Yours may have broken off inside the tank at the grommet. If so, its time for a new line/filter.
John Deere J3816... | Answered on Apr 21, 2015
1945: 542700
1946: 555334
Tractordata.com
Shows year of mfg as 1945.
John Deere... | Answered on Dec 02, 2019
The oil inside for the reverser is good? You found that the oil level was correct, the fluid was clean and no further actions were needed? Usually the failure is the clutch pack but that is seen in the fluid. Can you feel or notice that the shift lever is moving into the gear selection correctly? Do you notice, feel or hear that reverse gear is engaged when selected. Do you hear any noises or sounds that weren't there before the failure? Did this failure happen out of the blue or have you noticed reverse acting up for a while now? Please let me know. Good luck.
Order the service manual from John Deere.
John Deere... | Answered on Nov 30, 2019
Request the diagram from John Deere.
Request a starter wiring diagram from John Deere.
Request the wiring diagram (not a schematic) directly from John Deere.
There are video's of how to do this on u tube .
John Deere... | Answered on Nov 28, 2019
Search for part AM106852 but not sure its wise to spend over $100US on a carb for a 15 year old machine. Problem could be crankcase leak.
Should be able to find a different source for under $30. Look for numbers stamped on the carb and internet search those numbers for a different source.
John Deere... | Answered on Nov 19, 2019
IM SURE DEERE SUGGESTS THEIR OIL BUT ANY GOOD SYNTHETIC 2 STOKE OIL IS FINE
John Deere... | Answered on Nov 12, 2019
My guess is water in fuel.
You can verify fuel issue by removing air filter and spray a short 1 second burst of starter fluid into carburetor and promptly crank engine. If it's a no fuel in carb issue it will fire and run a few seconds until starter fluid is expended.
Disconnect fuel line at carburetor and capture sample (cup or so) while cranking engine.
Put sample in a small clear glass container. Look for an obvious horizontal line... fuel floats on water. Any sign of water and youll need to drain the tank AND carburetor bowl.
Then get fresh fuel in a clean empty container... dont use what you might have.
Comment here and I'll assist further I'd not a fuel issue.
John Deere... | Answered on Nov 09, 2019
http://manuals.deere.com/cceomview/OMM146413_G1/Output/146413g112.html
John Deere... | Answered on Nov 05, 2019
John Deere J3816 Chaninsaw Switch Logo
1 questions posted
Top John Deere Garden Experts
Dave
Joseph Mueller
Joseph Mueller
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
View Most Popular
John Deere Garden
  • John Deere Garden
Most Popular Question
fuel line in tank come loose connect
  • Garden
