20 Most Recent Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Questions & Answers
Ryobi CS30 Spool Retainer wont come off!
No trick - sounds like it is stuck!
Can you take it back?
If no - well - keep trying :(
Are you taking if off to put on other head attachment?
9/2/2022 8:53:25 PM • Ryobi 30 Cubic... • Answered on Sep 02, 2022
2answers
Ryobi cs30 starts fine, but idles way too fast
you need to take your air filter off and look into the throat of the carbruetor to see if the ""Butterfly""
is still intact and working not the choke butterfly its the one closest to the engine that moves with the throttle and be sure it is still there and moves as you move the throttle.... open is horizontal and closed is not quite 90 Degrees. check to see it is tight and in the center if the throat when closed.
you may have to remove the carb. to see it function more clearly
make sure the throttle cable is free and not binding any where and to be sure of its adjustment to allow the throttle to return to the idle position.
lubricate the cable from the trigger to carb. wd 40 is ok.
if all above is ok then find the L on the carb. and ccw it 1/8 turn to ritchen it alittle to help slow the idle down some to a respectable level
12/28/2021 9:24:09 AM • Ryobi 30 Cubic... • Answered on Dec 28, 2021
2answers
Was told to replace carburator
well if anyone is going to have that parts then its gonna be Ryobi the best solution I have to this is to contact them directly and even order the parts from their website
https://www.gardnerinc.com/recons/splash.php
The above link is to the ryobi outdoor parts replacement store.
4/16/2019 5:28:46 AM • Ryobi 30 Cubic... • Answered on Apr 16, 2019
2answers
Installing new string line for Ryobi 4 cycle straight shaft s430
Go to www.managemyhome.com and download a free copy of the onwers manual.
1/13/2019 5:36:59 AM • Ryobi 30 Cubic... • Answered on Jan 13, 2019
I have a Ryobi S430 4 stroke Weed Eater Trimmer. How many times do i pump the choke (primer) to start cold?
chokes are an obstruction placed over the inlet to increase the vacuum in the carby and cannot be pressed Primer bulbs are used to suck fuel through the diaphragms to expell all of the air in the system to allow starting normally press the primer bulb until it is full of fuel apply the choke and pull until it fires remove the choke and at full throttle pull until it starts
3/21/2018 12:08:10 AM • Ryobi 30 Cubic... • Answered on Mar 21, 2018
I have a 22cc Mcculloch gas trimmer. I believe the model is 3315.
The screen in the carburetor might be clogged, blow it with compressed air, reinstall it and see how it goes.
12/17/2017 7:22:22 PM • Ryobi 30 Cubic... • Answered on Dec 17, 2017
Ryobi ry34440 4stroke weed eater starts running bad after 15-20 minutes
make sure that the vent to the fuel tank is working
12/15/2017 10:19:44 PM • Ryobi 30 Cubic... • Answered on Dec 15, 2017
My Ryobi 990r has occasional
sounds like an ignition problem, probably in the module.
11/19/2017 4:02:22 AM • Ryobi 30 Cubic... • Answered on Nov 19, 2017
0answers
3answers
I have a stihl km
20 to 1
8/3/2016 12:25:32 PM • Ryobi 30 Cubic... • Answered on Aug 03, 2016
3answers
Return fuel nipple is broke from finger pump
The part previously recommended is not the correct part if it is the return line that is bad. Return line does not use the filter. If yours is like all the Ryobi units that I have seen you just need a piece (about 3-4" needed, but buy extra.) of 1/8 ID fuel line. You can usually order that from parts suppliers. Hardware stores will not have it. There is a fitting with a hose barb on it that fits through the tank. On the outside of the tank on the bottom there will be a round plastic ring, assuming the fitting is still in place and just the hose split at the fitting. Use a knife or thin blade of some type to pry off ring. It is actually around the hose that is over the barb. Keep ring, you will need again. Now push fitting up into the tank. You may have to trim off the hose that is outside the tank on the barb to get it to go into the tank. Shake tank around and get fitting out of tank. You will see there is a piece of hose on it yet. Remove that piece of hose. Now take the new hose and slide it onto the barb. It must go all the way to the top of the barb fitting so that the hose actually goes into the tank through the hole drilled in the tank. The OD of the hose acts as the seal to keep gas from leaking out of the tank. You may need to put some oil of some type (vegtable oil works well) on the barb and inside of hose to help slip it on and use some pliers with smooth or rounded jaws ( no serrations, will damage hose) to get hose on. Thread other end of hose into the fill hole of the tank and out the hole in the bottom of the tank. Hint: Straighten out paper clip or use small wire inserted into the hole from the bottom of the tank up towards the fill opening. Slip tube over that and use the wire to guid the tube directly to the opening. Pull hose through the tank. When fitting with barb and hose over it reached the hole in the tank it will resist being pulled through. Carefully pull firmly on hose to strech it so the hose/fitting "bulge" pulls into the hole in the tank. Look into tank and see when top flange of fitting is tight agains the bottom inside of tank. You should see bottom of barb outside of the tank with the hose on it. Once in place put the plastic retainer ring back over hose and push up to bottom of tank. It should fit snuggly when you get to the "bulge" area. Cut hose length as needed to fit onto straight tube fitting on primer bulb. Should be good to go. You may find that the other hoses are getting bad also and may want to change them at the same time, as they will probably be ready to crack also. You can reuse filter from tank if it is not plugged, just add a new hose as described previously. Otherwise you can order a new filter with the line already on it. That is the part that was recommended to you earlier. That line goes directly to the carb inlet barb. That barb is also hard to push hose on. Third line is from the return side of the carb to the suction side of the primer bulb. That is just a straight piece of 1/8" ID hose and pushes onto straight tube fittings, very easy to get hose on compared to barb fittings.
Hope this helps. Contact me if you have any questions.
8/24/2015 2:33:09 PM • Ryobi 30 Cubic... • Answered on Aug 24, 2015
I have a 30cc ryobi trimmer that will start but not run unless the choke is fully on. The moment I use the throttle or turn off the choke ,it dies. what could be the problem? thanks.
Hi Guy: The first thing I would check would be the fuel filter. Try pulling it out and giving it a really good clean. Probably a good idea to put fresh gas in at the same time if it's been sitting for a while.
8/11/2015 1:30:05 PM • Ryobi 30 Cubic... • Answered on Aug 11, 2015
2answers
Ryobi weed eater will only run if i hold the choke down
You need to check out this video...
6/2/2015 12:40:03 AM • Ryobi 30 Cubic... • Answered on Jun 02, 2015
2answers
I have a Ryobi weed eater (the kind with the
Look at this video...
6/2/2015 12:38:58 AM • Ryobi 30 Cubic... • Answered on Jun 02, 2015
2answers
Ryobi weed eater stalls when giving it gas
check air filter and spark plug if good carb adjustment is needed or carb may be loose. could be bad fuel water in gas will cause this
5/20/2015 1:58:38 PM • Ryobi 30 Cubic... • Answered on May 20, 2015
Starts and ticks over but stalls on opening throttle.
Turn your low side adjustment out 1/4 - 1/2 turn.
3/2/2015 8:14:06 PM • Ryobi 30 Cubic... • Answered on Mar 02, 2015
The line keeps feeding back inside the trimmer
On bottom of trmmer head it should have a knob or two taps that push in. Look on spooler there is an arrow that tells you which way to spool string.
12/17/2014 12:43:17 PM • Ryobi 30 Cubic... • Answered on Dec 17, 2014
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
495 questions posted
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
View Most Popular
Ryobi Garden
  • Ryobi Garden
Most Popular Question
30cc ryobi trimmer will start but not
  • Garden
