Try cleaning the door seal and add a little lube to it with a soft cloth.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
SOURCE: both Doors have weak seal, alarm is going off
the magnetic seal around the door lost it's magnetic power.
it needs replacement also.
SOURCE: Door open alarm sounds and door open indicator
The switch which detects whether the door is open may be malfunctioning or the control unit to which the switch is connected is faulty. If there is only one switch it may be the same switch which puts the light on as you open the door.Does the light come on when the door is open? If so the switch if there is only one, is probably ok but the control unit is faulty.Look around the edge of the door frame for switches and check they are not stuck or damaged. I hope I have been of help but please do not hesitate to ask if you have any further questions.
