20 Most Recent Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423 Questions & Answers
3answers
Condensation build-up on the bottom seal of Viking freezer door
I have seen this before and it goes beyond the seal, if it was the seal, you would see vapor trails around the area where the seal is leaking. You may have a breakdown of foam in the door. How old is it?
8/30/2019 1:07:31 AM • Viking 42 in... • Answered on Aug 30, 2019
Does the residue mold in the back of the refrigerator cause an order and what causes it to condensate on the back of the refrigerator
The moisture of the cooling coils and yes it does stink.
5/16/2016 7:39:23 PM • Viking 42 in... • Answered on May 16, 2016
2answers
All lights went out in my refrigerator/freezer
I have this side by side Viking- The worst product I ever bought. Nothing but problems. If I can give anyone advise do not buy one.
6/2/2015 12:20:24 PM • Viking 42 in... • Answered on Jun 02, 2015
Beeping- says temp is high
Ours did that when one of the kids left something sticking out so the door did not close all the way. Fridge could not keep up with an open door.
4/7/2015 7:18:31 AM • Viking 42 in... • Answered on Apr 07, 2015
Viking freezer leaking
you have a clogged drain, it is either clogged with ice or some kind of debris, thaw the freezer out and push a length of weed trimmer line down the drain. The drain is accessible by removing the back wall of the inside of the freezer. If there is no clog then the drain may be freezing up, if that is the case, take a piece of 14 gauge romex wire and loop it several times around the heating element at the bottom of the evaporator and push a few inches of it into the drain, this will get hot and transfer heat when it goes into a defrost cycle which is where the water is coming from in the first place
4/4/2015 1:27:33 PM • Viking 42 in... • Answered on Apr 04, 2015
2answers
How do I remove a Viking side by side refrigerator from the wall cabinet it is in?
There are adjustable wheels on front. Jack up front enough to grab the frame and pull out slowly. Be careful if you have water line for ice maker.
1/16/2015 1:53:35 AM • Viking 42 in... • Answered on Jan 16, 2015
Not dispensing ice
Try turning it off for 12 hr's. Buy the 5 yr. warranty on all ref. with ice maker
5/22/2014 1:48:42 AM • Viking 42 in... • Answered on May 22, 2014
Produce drawer freezes produce in back left corner. all things have been moved from vent to allow air flow. still freezing Viking 42 side by side
call viking sounds like you have a air flow problem from the freezer side.
5/4/2014 2:55:49 AM • Viking 42 in... • Answered on May 04, 2014
Hook up water line and water is coming from the bottom
Check your connections again.
11/29/2013 7:23:39 AM • Viking 42 in... • Answered on Nov 29, 2013
Our new 48" Viking side by side does not feed ice
I experienced the same problem several times with our VCSB483DSS also.What I found was that the ice come down the chute side way and got stuck at the flap in the door. As you continue to press for ice, the machine pushes more ice & they all back up in side the chute and in the door, ready to dump on unsuspecting person who open the freezer door.I think the the problems are:1 - over application of foam insulation in the chute pathway in the door.2 - possible bad timing on the flap opening causing the falling ice to get stuck.My solution for the past 6 years:1 - clean out the over application of foam insulation - this reduce the incident frequency from once a month to once or twice a year.2 - inform my family member that if while you pressed for ice, and the ice is not dropping, but you hear the motor still cranking away, stop pressing for ice immediately. Stick you finger up the dispenser to make sure the flap is open, and push the ice to un-stuck them. And finally, be prepare to get 2 cups full of ice.Viking may make professional quality fridge (13 years experience in restaurant business), but ice & water dispenser is not their strong point.
2/28/2013 5:39:15 AM • Viking 42 in... • Answered on Feb 28, 2013
2answers
We have a terrible odor
What does it smell like? Burnt plastic , mold , rotten food? Check gaskets and temp in fridge, food could be spoiling. It is tough to get serious odors out of fridges. Bleach, vinegar are good for killing odors. Check manufactures recommendations.
2/28/2013 5:13:35 AM • Viking 42 in... • Answered on Feb 28, 2013
2answers
42" SxS Viking Not making ice
You may have to unplug the the unit and thaw it out with a hair drier,and get everything dry.Then close it up and set the temp,and plug it in.It will take a while before it will start producing ice again normally.If I can help,let me know.
2/26/2013 7:22:43 PM • Viking 42 in... • Answered on Feb 26, 2013
Fridge too cold
all food in refrig freezing?
12/15/2012 10:14:24 PM • Viking 42 in... • Answered on Dec 15, 2012
2answers
My viking refrigerator freezer won t freeze
A lot of problems have been reported with this model,with the defrost timer not moving,Like a clock stopping,the defrost timer has stopped,and won`t allow the compressor to freeze the freezer unit.Most likely not to cool in the refrigerator either is it?If I can help anymore,let me know,but have the defrost timer checked or replaced.
10/6/2011 10:51:55 AM • Viking 42 in... • Answered on Oct 06, 2011
Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423 Logo
68 questions posted
Top Viking Refrigerators Experts
Jay Finke
Jay Finke
Jose Ramirez
john h
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Viking Refrigerators
Most Popular Question
our new 48 viking side side not feed
  • Refrigerators
