Re: No power to the wheels in forward or reverse new...
Verify that the battery is fully charged by testing it with a multimeter, also test your charger with a multimeter, they both should be putting out at least 12 volts
I had the same problem with my grandsons gator and I replaced the shifter switch. I called the peg perego department at 1.801.655.0800 and they sent me a couple of switches. Hope this helps
I recently tried
the DIY service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master. it wont move forward or reverse, engine is good both solenoids for forward and reverse work.
I don't have much technical knowledge but I just followed it step-wise, and works perfect! got it from www.reliable-store.comAll the best
Amazon.com, Inc.Amazon.com: Lil' Rider FX 3 Wheel Battery Powered Bike, Black: Toys & Games. ...On Motorcycle 6V Toy Battery Powered Electric 3 Wheel Power Bicyle, Red ... VTechGo! ... sound effects, working chrome colored headlight, and forward and reverse ...power wheels vehicle more to handle size, weight, and your child won't ...
Amazon.com, Inc.Amazon.com: Lil' Rider FX 3 Wheel Battery Powered Bike, Blue: Toys & Games. ...Sold by: Global Supplies (We currently can't ship to, HI, AK,APO,FPO, POB) .... Ride On Motorcycle 6V Toy Battery Powered Electric 3 Wheel Power Bicyle, Red ... sound effects, working chrome colored headlight, and forward and reverse ...
Have the controller module checked. You can also download the service manual from Pride's website. It has a lot of information in it as well as a complete wiring diagram.
If you have a volt meter, switch the volt meter to 12v, locate the motor in the back wheels and if you can see where the wires connect to the motor touch the terminals of the volt meter to the two connections and turn on the power wheels press the power pedal and see if you get a reading of 12v. If you can't touch the wire or where the wire connects try disconnecting the wires and testing it that way. If you have 12v at the motor then it seems the motor is shot. There should be two motors one fit each wheel and its unlikely that they would both go. If you don't have power at the motor try following the wires to the pedal and also the forward reverse switch. Test these in a similar fashion. Hope that helps
How old is the scooter? 2 Bleeps indicates low battery voltage, and such, require replacement. When you are in reverse, the current draw is a lot less than when going forward, just like not being sat on the scooter too. As soon as any real load is applied to the scooter, the power will drop down below 16v and will cause a controller trip (2 bleeps) However, this could also be caused by bad battery connections, either inside the battery box, or where the contacts meet on the bottom of the pack - onto the chassis. Check for discoloured pins / connections.
The result of data corruption that can occur when power is low enough to get interupted by the load of a motor. The above solution it the correct thing to try first/
I have a 6 volt battery power wheels car it has no reverse button the only button it has is just to make it go as I charge the battery it only goes in reverse don't know what to do that used to work fine it's at for a little while we charge the battery up and now it goes reverse instead of forward what should I do
If your batteries have ever gone dead, they can show fully charged, then completly discharge very rapidly. Take them to autozone and ask for a "load test". If they don't hold a load, replacement is nessary. [email protected] for more if the batteries pass load test
