20 Most Recent Fisher Price Power Wheels Barbie Mustang RideOn Questions & Answers
Does not operate in reverse
If the vehicle will not go in reverse, but works in both low and high forward speeds you most likely have a bad shifter switch. The shifter switch is only available in a shifter assembly found here: http://www.mendingshed.com/j4390-9209.htmlReplacing the shifter should get your Power Wheels running correctly.Thank you,ColleenCustomer ServiceMendingShed.com800-339-9297
4/12/2013 5:29:39 PM • Fisher Price... • Answered on Apr 12, 2013
How do I fix the Fisher price merry go round? And put it back together? The mechanism was made in Switzerland
How to assemble: Steps: Mechanism casing upside down: - insert man - insert on/off switch - insert small cover - insert small gear - insert H shaped part at the gear opening - align base and screws in w 2 screws Right side up: - attach big gear and axel to small gear inside casing - place scoring under axel and onto the base - align merri go round against mechanism and 2 screws Upside down: - screws 3 more screws of merry go round piece
7/19/2022 11:32:38 PM • Fisher Price... • Answered on Jul 19, 2022
2answers
Switch from French back to English
Check inside where the batteries are stored. There may be a switch that changes the language and it might have gotten jostled and switched on its own. If still no luck, remove and replace batteries to see if it resets. If that doesn't work contact Fisher Price customer service for more assistance. Bonne Chance! (That's Good Luck in French) If you haven't fixed your toy yet, you might already know that. =) Au Revoir
3/3/2022 10:19:10 PM • Fisher Price... • Answered on Mar 03, 2022
Fisher price talk to me does not turn on even with new batteries. Any suggestions.
try to reset, insert small thin object with the batteries in and the product turned on. And check that batteries are both the same bransd and heading in the right direction and use the recommend type or brand if they have one.
7/3/2021 5:11:40 PM • Fisher Price... • Answered on Jul 03, 2021
5answers
How to open FP music box record player, #995 or #995N
Fisher Price Music box: to open, remove the four screws from the bottom, open the two parts as wide as possible without using too much force. Using a small flat blade screw driver, insert between the red cover and white top where the wind up knob is located. Pry the red bottom out far enough to allow the ring surrounding the knob to slide under the red bottom. The box is now open.
After repair, and re-assembling, make sure the wider part of the wind up stop wheel faces the front of the player, otherwise the wind up knob catches and slows the mechanism.
11/22/2019 1:35:33 PM • Fisher Price... • Answered on Nov 22, 2019
My boys have used the handle bars of my Fisher Price Smart Cycle as a seat for some time now and I think they've broken them a bit as the handle bar flips back and forth. Is there any way to fix it?
As we can not fully see the damage my best bet would be to take it to a local "Mens Shed" where I'm sure they can fix it for you.
6/6/2019 4:51:42 AM • Fisher Price... • Answered on Jun 06, 2019
How do you repair a
my grandsons broke their mother's (and aunts') FP music box. There was almost no sound The teeth are simply a wind-up music box set, connected to a rod that transmits the vibrations to the diaphragm under the pseudo-tone-arm. I was able to fix by placing a cotter-pin on the rod in the arm at or near the junction and then trim with wire cutters to the correct size. I checked the diaphragm first by tapping it through the arm/table connection.
4/6/2019 6:14:20 PM • Fisher Price... • Answered on Apr 06, 2019
Fisher price i play piano won't turn on, it lights up, but will not stay on.
Try to put it new batteries. If not notify the person you bought it from or the store and ask for help or refund.
1/29/2019 7:36:12 PM • Fisher Price... • Answered on Jan 29, 2019
Fisher price smart cycle new batteries but when I turn it on nothing happens
its broke buy a new one
10/10/2018 10:19:55 PM • Fisher Price... • Answered on Oct 10, 2018
Where can I find the battery pack and charger for the Fisher price imaginext remote control big foot?
Sorry we have no parts locator service here.
6/15/2018 9:04:47 PM • Fisher Price... • Answered on Jun 15, 2018
Our fisher price ixl will
Has anyone been using anything beside the stylus your suppose to use? Cause that can damage the screen and make it not come on. Also i seen you said it won't recognize when hooking it up to computer. Make sure the program is installed on your computer and then unhook the cords from device and computer and reinsert them. Let me know what happens.
1/29/2018 7:09:28 PM • Fisher Price... • Answered on Jan 29, 2018
I bought the Fisher Price
If you put each figure in two socks and tossed it in the dryer, the socks should protect them from the tumble. I just don't know how long to keep them in the dryer. They might deform if left too long. Once deformed, there is no fix. I imagine a similar effect achievable with a hair dryer, though a lot more tedious.
1/3/2018 6:17:47 AM • Fisher Price... • Answered on Jan 03, 2018
Looking for eggs and veggies for the Fisher Price laugh and Learn Farm.
hi Patty. i have looked all over the internet just for the parts you are asking for but can not find anything. but you could go to this link and see if its any good to you. if not have you tried ebay?. where to buy eggs and veggies for the Fisher Price laugh and Learn Farm...
12/1/2017 7:36:59 PM • Fisher Price... • Answered on Dec 01, 2017
The product code mentioned on
no contact the manufacturer direct for spare parts
11/12/2017 2:11:40 AM • Fisher Price... • Answered on Nov 12, 2017
Fisher Price Power Wheels Barbie Mustang RideOn Logo
5 questions posted
Top Fisher Price Toys Experts
ADMIN Andrew
ADMIN Andrew
Jennifer Rock
Jennifer Rock
NOEL
NOEL
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
View Most Popular
Fisher Price Toys
  • Fisher Price Toys
Most Popular Question
  • Toys
