20 Most Recent
Electrolux EIDW6105GW 24 in. Built-in Dishwasher Questions & Answers
I have an Electrolux EIDW
Hi
The issue is either with the wash pump that is going bad or
the motor itself that is unable to run. As the washer fills and then drains
immediately so the pressure/float switch should also be checked. Hope this
helps...please post back for further assistance.
Daniel
Dishwasher starts to fill then
Hi
Error code F12 means a shorted connection or wiring on keypad. Turn off & unplug the dishwasher for 2-3 minutes and check the error doesn't appear. If this doesn't resolve the issue then you'll need to disassemble the keypad and check the connections on the keypad, also make sure that the wiring is also fine. If the connections and wiring seems to be fine then use a multimeter to check the continuity between the connections on the keypad. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
I have a electrolux eidw6105 all lights are flashing
very important! the machine must be perfectly level or slightly tilted higher in the front . If not the leak detector function will engage and the machine will not operate. Try raising the adjustable feet behind the kick plate.The machie may reset without removing it.
The touch control pannel on my eletrolux
Have you got any indication of error codes in the display if not check the child safety lock is not set or the disable of display is not set.I guess you have a manual it gives all the error codes in this.
Hope this helps.
How do I get the Electrolux dishwasher to dry the dishes?
I've got a suggestion and at first it may sound like I'm pulling it out of my...left field. I'll tell you the what and then I'll explain why.
Try this, take a rag or paper towel and soak it with "rinse aid" AKA, "jet dry" and apply it to the top of the tub and to a lesser degree the sides as well. I suggest this to all my customer's with new dishwasher's. Now the why...all dishwasher's require assistance to dry your dishes, some more than other's. Hence the need for an additive such as jet dry, it is simply a wetting agent which help's the water run off the dishes and as a result they dry better. So why put it on the tub ? Glad you asked. The reason is exactly the same, on older dishwasher's that have had many year's of use the tub has already built up some wetting agent on the tub just by normal and continued use, the new obviously has not. The only jet dry the new one has is the added amount in the dispenser. Over a short time of regular use the unit would start to dry better on it's own, this just speed's up the process. By adding the jet dry to the tub you create a seathing action allowing water to run off before & during the dry cycle as to not have water
in the form of condensation dripping back onto the dishes when the cycle is complete, which leaves you with dry dishes as opposed to wet dishes. Make sense ? I hope so, it really work's.
Hope you found this helpful. If so please rate the info you received frome jere at "fixya" today and good luck. Let me know if I can assist you further.
I hope you didn't find this too difficult to read, I had to use my iphone, it's the only internet connection I have at the moment.
Macmarkus :)
