20 Most Recent
Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher Questions & Answers
Electrolux dishwasher leak detector light
This was a good answer. It reset the error. But once we started the washer up again it threw the same error. Next step, remove it from the cabinet and check for leaks.
How do i find the leak sensor on my electrolux dishwasher?
Good Afternoon Friend,
I understand you want to know where the leak sensor is on your Electrolux dishwasher, model# EDW5500DSS. Typically the leak sensor will be located underneath the tub area. There are no diagrams that show exactly where the sensor is located. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and will be able to best assist. Hope this is helpful.
-Best Regards-
WP
ALL LIGHTS BLINKING
There is an older post that may help:
http://www.fixya.com/support/t2062601-electrolux_dishwasher_all_lights
What is error code "02"
Getting an Error Code 2 on your dishwasher, means there is something going on with the turbidity sensor. This is the sensor that determines how dirty the water is which in essence determines how long the cycle will run.
What you can try to do is to reset the appliance for 30 minutes. You will do this by cutting the power at the circuit breaker and leaving it off for no less than 30 minutes. Try running the cycle again and if you are still receiving the Error Code 2, I would recommend contacting the manufacturer for further assistance.
Electrolux dishwasher all lights blinking and wont
Remove the toe kick by loosening 2 screws. There is a panel there with little lights that correspond to specific problems. The light that is on will correspond to the problem that the dishwasher has detected. Correct the problem and you should be good to go. I have no idea why this is not in the instruction manual. A common one is that there us a leak that the dishwasher has detected, normally in the drain pipe.
Error code 02 ewd6505gso
Sandra Lawson,
-Best Regards-
