I suggest you viisit www.invebo.com and enter your dock serial number. You get access to diagnostic and repair videos and it tells you what spares you need and how to fit them yourself. All kits you get a new docking connector of the later, tougher design included in the kit. Everything is supplied on a no-risk 'buy & try' basis so you can send back if the problem isn't solved.
Hi, I suggest you visit www.invebo.com and enter your dock serial number. You get access to diagnostic and repair videos and it tells you what pods and phones your dock is compatible with. Also there is a diagnostic video that helps you decide what's wrong and kits and detailed instruction videos that lets you fix the problem yourself. If your dock connector is faulty than you can fit the charge upgrade or upgrade to Bluetooth on a Bose SoundDock Original for less that the cost of a repair. All kits you get a new docking connector of the later, tougher design included in the kit.
The problem could be your dock resetting if itis a type B build. I suggest you visit www.invebo.com and enter your dock serial number. (Several builds of Sounddock look identical butthe internal hardware is different) You get access to diagnostic and repair videos and it tells you what pods and phones your dock is compatible with. Also there is a diagnostic video that helps you decide what's wrong and kits and detailed instruction videos that lets you fix the problem yourself. If your dock connector is faulty than you can fit the charge upgrade or upgrade to Bluetooth on a Bose SoundDock Original for less that the cost of a repair. All kits you get a new docking connector of the later, tougher design included in the kit.
Diagnostic videos and spares for the Bose SoundDock. There are several builds of the Bose SoundDock Original that look identical from the outside. If you visit invebo.com and enter your dock serial number you get access to the resources that tell you which version the dock's internal hardware you have in your dock, diagnostic and self repair videos and what kits you should buy to fix or upgrade to charge or Bluetooth wireless streaming. All spares are supplied on a no-risk 'buy and try' basis.
51 questions posted
681 Questions
296 Questions
322 Questions
225 Questions
200 Questions
