20 Most Recent Bose 3 2 1 GSX System Questions & Answers
I check 321 gsx sbose system that you use to play the DVD and it claims that it supports CD-R, CD-RW, SACD, DVD-R, DVD+RW, DVD-RW, DVD+R, DVD, CD, Video CD (NTSC, PAL). So make sure that the DVD that you burn the video onto should be compatible with your DVD player. And you can also refer to this post about burning mp4 with nero to make sure that you burn with right steps.
Bose 3 2 1 GSX... | Answered on Apr 15, 2019
Your TV may not likely be compatible with your Bose System.You may have to try your Bose System with another TV to know if it's a compatible issue or a video fault in the Media Center
Bose 3 2 1 GSX... | Answered on Oct 28, 2018
You are correct,since you already tried another remote,the sensor in the Media Center may be faulty and would need a replacement.
The power supply is 29 volts raw voltage,the IRFI44N fet on the power board is used is a switcher.
It reduces the voltage to 17 volts which is required for the AV3-2-1 meda center.The higher voltage biases the sound to cut off and can blow the drivers,try changing the fet and see if plays........
Bose 3 2 1 GSX... | Answered on Sep 01, 2017
Performing a product reset To reset your system, follow these steps:
  1. Turn your system off. Wait until "Saving your music information" disappears from the display
  2. Unplug the Acoustimass® module power cord from the power outlet
  3. Wait 60 seconds
  4. Plug the Acoustimass module power cord into a working power outlet
  5. Turn the system on
Note: After the reset, wait several minutes before playing stored music (stored music may not be immediately available depending on how many CDs have been stored). All other sources are available, immediately after the system is turned on.
Bose 3 2 1 GSX... | Answered on Feb 06, 2016
check the power suply behind the acoustimass set to 115v, not to 230, that will solve you problem
Bose 3 2 1 GSX... | Answered on Aug 26, 2015
-If this happens on all DVDs, then this may need to be repaired (Bose will repair this for free if this is the case- they can test it too) -If this happens on some or most DVDs, you can try a firmware update. Call Bose at 800-367-4008 and tell them about this. Request the most recent software/firmware update disc.
If you haven't already, just try resetting this first. (unplug the power cord from the acoustimass module for about 30+ seconds and try again)
If this happens primarily on rentals or home-made dvds, an update will most likely fix the problem.
Bose 3 2 1 GSX... | Answered on Feb 05, 2015
BOY OR GIRL ITS BROKEN
Bose 3 2 1 GSX... | Answered on Nov 06, 2014
Bose 3 2 1 GSX System Logo
384 questions posted
Top Bose Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Bose Audio Players & Recorders
Most Popular Question
set up wireless speakers bose 321
  • Audio Players & Recorders
