20 Most Recent
Kenmore 27.6 cu. ft. French-Door Bottom-Freezer Refrigerator Questions & Answers
Setting the controls
These are computer run items now. If you unplug it for 2 or 3 minutes does it reset itself? If not try pressing refrigerator an ice buttons together. If that does not work the evaporator fan or control panel needs to be replaced. That about all one can do these days other than keeping the air ways clean so fan is clear. But ecen that will not stop these voltage spikes on the line from ruining good appliances.
Error code b on kenmore chest freezer
LOW / NO BATTERY ALARM
The Low/No battery alarm will activate when the
power level of the battery becomes low. The display
will alternate between "b" (Battery, See figure 8) and
the cabinet temperature, the red alarm light will
become illuminated and the control panel will beep
every five seconds. To stop the audible alarm (beep),
press the "ALARM RESET" button. The red alarm
light will remain on and the display will continue to
flash until a new battery is installed. This same alarm
will activate if there is no battery installed
Where is the 9V battery located on a Kenmore upright freezer model 970
The location of the 9V battery on a Kenmore upright freezer model 970 can vary depending on the specific model and design. However, in general, the 9V battery is typically located in the control panel or on the back of the freezer near the compressor. You may need to consult the freezer's manual or contact Kenmore customer support for more specific information regarding your model.
Where is adjustable cold control on kenmore model 15098 freezer
Found this
The temperature is factory preset to provide satisfactory food storage temperatures. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. If a colder temperature is desired, turn the temperature control knob toward MAX and allow several hours for temperatures to stabilize between adjustments.
In my experience, the temperature adjustment knob is behind the grill on the side. They put it hidden there because you hardly ever need to touch it. The model number isn't quite right for a Kenmore. It should be 3+5 numbers 123.12345 like this one 253.12502
https://i.sears.com/s/d/pdf/mp-tc/spinpdf/spin_prod_1011956212
