20 Most Recent
Audiovox UV8 Car DVD Player Questions & Answers
Hooking up backup camera to jensen uv8
That wire needs to run back and be hooked to the revese bulb. When the car is in reverse, activating the reverse lights the unit will get a signal knowing that you can use the camera
What are the input wires on a audiovox amp777
The Audiovox AMP777 is a 4-channel power amplifier, and the input wires will depend on the audio source you are using. Typically, the amplifier will have RCA input jacks for left and right channels, and you would use RCA cables to connect the audio source to the amplifier. Some amplifiers also have a high-level input option, which would allow you to connect speaker wires directly to the amplifier's input terminals. However, it's always best to consult the user manual or contact Audiovox support for specific wiring instructions for your amplifier model.
My cd runs but will not play the cd
Quite common problem. Repair it or replace your player if repair cost is too high. Personally, I stopped using CD players time ago: I use a mp3 player.
