20 Most Recent Audiovox Jensen In-Dash DVD/CD Receiver w/ 7 LCD Screen" Car Video Player Questions & Answers
The remote has nothing to do with bypassing the e-brake. Not to mention the fact that it is illegal anyway.
Audiovox Jensen... | Answered on May 09, 2011
Try disconnecting the power from your battery, it may reset the head unit.
Audiovox Jensen... | Answered on May 04, 2011
try 123456789.
Audiovox Jensen... | Answered on Dec 01, 2010
check this out man, go to fm/am mode. with the remote hit the setup botton. then enter 543210 and be sure it beeps on every diget. then hit the hammer/screwdriver icon and turn the parking brake "on"
Audiovox Jensen... | Answered on Nov 02, 2010
Is there a part number of the In Dash DVD/CD? I mean I could pull a manual would give you a hint how to use the deck.... This is the best I can do without knowing the model number of your deck... Hope this helps
http://www.docshare.com/doc/225137/VM9510-Manual
Audiovox Jensen... | Answered on Sep 24, 2010
isn't there a way to bypass the parking brake so my video plays anytime i want
can only see my video when i park and i bought for long trips so my girlfriend wont get bored
VM9311TS
Audiovox Jensen... | Answered on Sep 18, 2010
use toggle switch on inout bypass code with remote
Audiovox Jensen... | Answered on May 12, 2010
ground wire to a normal 2 position toggle switch. put dvd in. turn switch on then off then on. there ya go.
Audiovox Jensen... | Answered on Mar 24, 2010
New player? Under warranty? Take it to whoever installed it. Sounds like a weak laser, or a laser alignment problem. Could also simply be a dirty laser lens, but proper cleaning requires disassembly (those laser cleaning discs are hit-n-miss, and I've seen them actually damage the laser pickup, so I do not recommend them).
Audiovox Jensen... | Answered on Nov 21, 2009
it is muted. try to look for the speaker icon with an "X" that indicates muted speakers. If no such icon, your volume is ZERO. Now press the + key with the speaker icon which indicates the volume control.
Audiovox Jensen... | Answered on Oct 09, 2009
in the directions it should either tell you to attach a wire from the radio to the ebrake so you can get video. i dont like that idea . first try and ground and ground the wire to the back of the unit. some manufactures incorparate a sequense ex- pull e brake three times then the video will work . what i have done with these is put a small button in the center console or somewhere out of the way . if you want to hook it up the way they want it i need to know what kind of car you have ...
Audiovox Jensen... | Answered on Jun 19, 2009
yes its saying in toorder to play dvd's u must engage parking brake which means the wire is suppose to be hooked up to the parking brake....BUT i know the trick to make it work where u can play dvd's and drive
Audiovox Jensen... | Answered on May 31, 2009
sounds like a bad spot in your ribbon cable. it runs form the laser assembly to the circuit brd. you could have some dirt on the sled rails..either way the radio will have to be taken apart..if you can do this yourself the ribbon cable is not too expensive...labor is what gets you..
Audiovox Jensen... | Answered on May 09, 2009
go to www.jensen.com and download from there is free,good luck.
Audiovox Jensen... | Answered on Mar 23, 2009
Audiovox Jensen In-Dash DVD/CD Receiver w/ 7 LCD Screen" Car Video Player Logo
Popular Tags
32 questions posted
Top Audiovox Car Audio & Video Experts
Marvin
Marvin
Ekse
Mark Skinner
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Audiovox Car Audio & Video
Most Popular Question
touch screen lights up
  • Car Audio & Video
