20 Most Recent
Audiovox JENSEN VM8012 3" WIDESCREEN MULTIMEDIA RECEIVER Questions & Answers
Is there anyways to override the parking brake
g brake line is just an earth, its a safety precaution so you dont watch and crash, if you want to have it play while you drive simply earth that wire somewhere else. connect it to the earth on your dvd player itself that will trick the system into thinking the park brake is up.hope this helps and please drive carefully :p
I'm getting power to it but the screen isn't
how do you know you're getting power to it? did you check for power at the conector? make positively sure you've got a good ground and that it's hooked up right. and check the fuse in the back of the radio, and in line with the wiring.
How do u wire a vm8012
myhpcamera when i switchon showing battery low nobody to attend the fault[battery full charge condition]
I have my jensen in a 2006 pontiac vibe. after
There is a protection fuse in the back of the radio itself, sometimes in the wire comming off the radio. alot of times when boosting a car it will receice a power spike, and blow this fuse.
What are the input wires on a audiovox amp777
The Audiovox AMP777 is a 4-channel power amplifier, and the input wires will depend on the audio source you are using. Typically, the amplifier will have RCA input jacks for left and right channels, and you would use RCA cables to connect the audio source to the amplifier. Some amplifiers also have a high-level input option, which would allow you to connect speaker wires directly to the amplifier's input terminals. However, it's always best to consult the user manual or contact Audiovox support for specific wiring instructions for your amplifier model.
