20 Most Recent Frigidaire 1.6 Cu. Ft. Over-the-Range Microwave Questions & Answers
GE Profile JEB100W microwave says HOT when you
The humidity sensor and temperature sensor are plugged in the wrong plugs on the main board. Swap them and your problem will go away.
3/29/2024 12:02:40 PM • Frigidaire 1.6... • Answered on Mar 29, 2024
How do I get the turntable turned back on when using sensor reheat.
I appreciate your post, friend! I see you are having trouble with the turntable motor on your Frigidaire microwave. The best way to reset your microwave is to disconnect power from it for roughly ten minutes. You can do that by flipping the household circuit breaker off. I hope that helps. -Matt
2/18/2015 4:19:37 PM • Frigidaire 1.6... • Answered on Feb 18, 2015
Microwave runs when door is open
Hey friend, thanks for your post!
From my understanding your Frigidaire microwave is running when the door is opened. I have identified a few possibilities could be the control panel or your door. Since it could be any one of these underlying issues I would recommend having a professional come and properly diagnose your appliance. -Matt
9/25/2014 7:40:17 PM • Frigidaire 1.6... • Answered on Sep 25, 2014
How do I change a microwave door switch
Good Afternoon Friend, I understand you are trying to change the door switch in your Frigidaire microwave. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest, especially when dealing with your microwave, contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to change the door switch with ease. Hope this is helpful. -Best Regards- WP
6/23/2014 8:32:52 PM • Frigidaire 1.6... • Answered on Jun 23, 2014
0answers
Frigidaire gallery otr microwave vent not working
Hello Lori Wilson - Thanks for your post! Generally speaking, the vent is not very strong. Try to place a single paper towel on the underside of the microwave. With the vent on, it should suction the paper towel to the bottom of the microwave. If not, I personally recommend contacting the installer to verify that the vent fan is installed properly and the exhaust outer is correct.
4/5/2013 5:11:07 PM • Frigidaire 1.6... • Answered on Apr 05, 2013
No heat in microwave
Do you have power and lights within the unit? If so, and the only thing that does not work is the heat, more than likely you are looking at replacing the magentron. If you dont have power and like, it could be a control board issue. This is not a typical do it yourself job, please consult a professional or your manufacturer.
9/11/2012 7:43:56 PM • Frigidaire 1.6... • Answered on Sep 11, 2012
Microwave not working unless I hold & push up the door. what's wrong?
You have a defective bottom door switch or possibly its mount is loose.The service manual is here.Also see my help file on door switches here. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
5/31/2012 7:07:45 PM • Frigidaire 1.6... • Answered on May 31, 2012
Glbm188hb turntable not working
Yes! I agree with Chris the turntable motor will need to be replaced, please remember there are lethal voltages present, so remember to unplug and short the high voltage capacitor across the 2 points with a long screwdriver.
3/13/2012 1:18:23 AM • Frigidaire 1.6... • Answered on Mar 13, 2012
Frigidaire microwave not heating over the range
Hello
Try to cook something simple such as microwave popcorn. If the unit does not light up or turn on, check the outlet with another appliance to make sure the outlet is functioning correctly.
Check the fuses or circuit breakers in you house. If the outlet does not work after testing it with another appliance, try to plug the microwave in a different outlet.
Check the hinges and door hooks to make sure the door is closing properly. Look to see whether a small piece of food is clinging to the door, preventing it from closing all the way. Check the release mechanism and the rotating plate to make sure they can move freely as well.
Plug in the microwave and start it a the bag of microwave popcorn inside. If the lights go on but it is not producing heat, listen and try to hear whether the unit sounds the way it usually does. If it does not, there might be problems with the circuit board. This will need to be repaired by a certified Frigidaire professional.
Check the display that shows the time and power. If the display is flickering but it does not alter the operation of the microwave, it is not a problem. If, however, the lights flicker and your food is not heating, there may be a problem in the microwave cabinet.
Listen for buzzing sounds. If there is a buzzing sound and no heat is being produced, you may have to get a new magnetron, power diode, or high-voltage capacitor. These can be purchased from a Frigidaire retailer.
Look at the handle on the door. The most common complaint about all models of the Frigidaire microwave, according to Consumeraffairs.com, was cracked or broken door handles. Frigidaire will replace faulty handles while the oven is under warranty. In many cases, they will replace the handle even after the warranty expires for a "reasonable" amount of time.
10/5/2011 12:42:07 PM • Frigidaire 1.6... • Answered on Oct 05, 2011
Does microwave have an internal fuse
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;
9/11/2011 12:04:06 AM • Frigidaire 1.6... • Answered on Sep 11, 2011
THE GLASS PLATE DOES NO LONGER ROTATE
heatman101
9/8/2011 3:02:34 AM • Frigidaire 1.6... • Answered on Sep 08, 2011
Microwave works but the heating portion
heatman101 ',;./
8/13/2011 1:31:11 AM • Frigidaire 1.6... • Answered on Aug 13, 2011
Microwave will light up and motor will run but wll
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
heatman101
2/22/2011 10:04:18 PM • Frigidaire 1.6... • Answered on Feb 22, 2011
Turntable is very sluggish, intermittent (stops
The turntable motor or belt are replaceable, but finding the parts for some models can be challenging...Here is a tip that will help you to figure out what is wrong with your Microwave Oven....Microwave Oven Basic Troubleshooting Tipsheatman101
11/16/2010 2:12:48 PM • Frigidaire 1.6... • Answered on Nov 16, 2010
We had sevseral boiling pots going underneath the
The main power fuse inside the MW may have been blown from the steam shorting out the circuitry. If so this fuse probably can be replaced. Lowes has replacement fuses.
11/14/2010 10:28:33 PM • Frigidaire 1.6... • Answered on Nov 14, 2010
Frigidaire 1.6 Cu. Ft. Over-the-Range Microwave Logo
67 questions posted
Top Frigidaire Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Jerry Naidoo
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Microwave Ovens
Most Popular Question
frigidaire microwave not heating over
  • Microwave Ovens
