20 Most Recent GE 24" Built-In Single Gas Wall Oven Questions & Answers
Why the piolet does not lile inmy Ge wall oven when turned on
Thermal Fuse If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement. Igniter and Gas Valve Coils TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ? Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant. Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit. Air Flow and Heat The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all. Warning There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
4/2/2015 8:07:24 AM • GE 24" Built-In... • Answered on Apr 02, 2015
We have a GE Wall Oven #JGRS14BEWBB, After baking 30-45 minutes, error code E3 flashes on. What does this mean?
There is a good chance that the oven sensor is going bad.
11/22/2014 5:28:21 AM • GE 24" Built-In... • Answered on Nov 22, 2014
Clock has never kept time, more recently the
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
%^e
3/20/2013 10:25:17 PM • GE 24" Built-In... • Answered on Mar 20, 2013
When trying to start oven for baking. I set the
well, at least your door hinges are still working. Let me guess, this is less than 6 months old. Every review of these ovens shows the door function breaking. I wish I had better news...and good luck!
1/4/2011 5:09:01 PM • GE 24" Built-In... • Answered on Jan 04, 2011
Oven dont heat up
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
11/24/2010 1:06:52 AM • GE 24" Built-In... • Answered on Nov 24, 2010
I have the model JGRP17WWW
I completely agree. It is ridiculous. This problem can be caused from the thermostat inside the oven, or the control panel. If the control panel is not receiving the signal from the thermostat then it will continue to heat. It is a possibility that the repairman did not get the thermostat hooked back up and the repair will be on them.
10/26/2010 7:02:57 PM • GE 24" Built-In... • Answered on Oct 26, 2010
Oven does not light. Oven ignitor does not glow.
remove the lower pan drawer to access the ignitor and with the power off check it for continuity,it may have burned open, they do get extremely hot 1800 degrees Farenheit,then check for voltage at the connector if the ignitors good,then its back at the oven control
10/18/2010 2:30:51 PM • GE 24" Built-In... • Answered on Oct 18, 2010
Oven not working f7 light on
F7 indicates a stuck button or the ERC needs replacing. This link should walk you thru testing and replacing the problem
http://appliancehelponline.com/ovenerc.html
6/28/2010 7:49:19 PM • GE 24" Built-In... • Answered on Jun 28, 2010
I need the squematic wiring GE 24" Built-In Gas Oven
I have the same problem -- did you ever get this question answered?
6/14/2010 2:59:39 PM • GE 24" Built-In... • Answered on Jun 14, 2010
I bought a used 24 inch GE gas wall oven, changed
Many times, unless you have the universal, the orficies have to be changed. From nat to LP. they do make a universal type.
12/15/2009 11:35:04 PM • GE 24" Built-In... • Answered on Dec 15, 2009
PURCHASED NEW GE WB27T10327 OVEN
Hi.
I do not have wiring diagram for this ERC. They had never been made available online by GE.
Here GE contact contact 1-800-626-2005.
All I can give you is the oven diagram below:
11/6/2009 4:31:18 PM • GE 24" Built-In... • Answered on Nov 06, 2009
2answers
Oven temp does not remain constant. changes + /-
Sounds like either an intermittent temperature sensor or its wiring, OR a problem with the electronic control.
We repair a lot of controllers with this sort of symptom.
Best Regards,
Bruce
www.fixyourboard.com
10/31/2009 8:41:25 PM • GE 24" Built-In... • Answered on Oct 31, 2009
I asked yesterday about a GE Oven not working. I
Happy we could be of service to you.
10/31/2009 7:22:20 PM • GE 24" Built-In... • Answered on Oct 31, 2009
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
10/30/2009 4:19:58 PM • GE 24" Built-In... • Answered on Oct 30, 2009
GE 24" Built-In Single Gas Wall Oven Logo
42 questions posted
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Ovens
  • GE Ovens
Most Popular Question
ge wall oven jgrs14bewbb after baking
  • Ovens
