20 Most Recent GE JTP15 Electric Single Oven Questions & Answers
Try unpluging the oven for about 5 minutes and then plug it back in. It should reset itself.
GE JTP15... | Answered on Sep 01, 2018
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
GE JTP15... | Answered on Jan 06, 2017
you have to push the bake or broil button first then set a temperature in it it is not a smart oven you have to give it directions
GE JTP15... | Answered on Nov 06, 2015
Hello & Welcome to FixYa
Correct, it is recommended to replace the control panel completely. Please get back to me if you have any other questions.
Kevin
GE JTP15... | Answered on Mar 01, 2015
I had this code come up on a double wall oven once and I fixed it myself for $200 less by ordering the part and using Repair Clinic.com for step-by-step instructions. It still cost me $100 + for the part and $65 for a serviceperson to tell me what I already knew (the code was F7) and it seemed confusing at first but I did it! Make sure to turn the electric off first from the fuse box!
GE JTP15... | Answered on Jul 14, 2014
I ordered a new control board and it did not fix my issue, I found that my ribbon cable is touching one of the boxes and getting hot, when I bend it away from the board, my button works, I used electrical tape to keep it from touching. It could be just a bad ribbon cable instead which costs about 25.00 , you have to know the exact number of pins your unit will need
GE JTP15... | Answered on Jun 20, 2014
Based on you description, fail codes, you've got a temperature sensor failure and or a loose connection in your sensor harness.
GE JTP15... | Answered on Apr 24, 2014
It may be possible that the electronic control is bad. On some models there are three relays one for the bake and one for the broil and one for the common. This one goes out and the bake and broil will not work. The control is fairly expensive you may want to have a tech check it out.
GE JTP15... | Answered on Nov 26, 2013
GE JTP15 Electric Single Oven Logo
151 questions posted
Top GE Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Ovens
  • GE Ovens
Most Popular Question
replace self cleaning element in jtp15
  • Ovens
