20 Most Recent Bakers Pride Y-600 Gas Single Oven Questions & Answers
Turn off gas supply. Open panel on left side. Loosen the top and bottom unions. Remove thermostat capillary line from the oven. Now remove thermostat with 2 pipe wrenches. install new thermostat and attach assembly to the unions you loosened. Now insert the capillary line back into the oven.
Bakers Pride... | Answered on Dec 16, 2016
I would suggest that the thermostatic gas control valve is faulty and you will require a Gas Safe engineer to verify and replace the item.
Bakers Pride... | Answered on Aug 23, 2014
normally you have three types of baking methods.
1. Top only
2. Bottom only
3. Both. -use the setting to this configuration then you will be good to go.
OR
Only one part of your oven is working. THIS can NOT be due to a circuit issue. The other heating wire might be probably damaged. Get it replaced. Will cost you very less about USD5-10.
Bakers Pride... | Answered on May 11, 2014
Check your exhaust does the flame on the burner look like it is starting to float after a few minutes if so you are starving for secondary air
Bakers Pride... | Answered on Feb 05, 2014
When your looking for this part it is called the "Stone Deck"
36" X 60" for most Y600 Models. FixYa is a "help you" site not a full blown retail outlet.
This is the Y-600-(old style) manual:
http://www.bakerspride.com/pdfs/Y-600%20Parts%20List%20OLD%20STYLE%207-05.pdf
This is the Y-600 manual: http://www.bakerspride.com/pdfs/PartList/Y-600%20Parts%20List%20U6050A%208-08.pdf
This is the Y-600-DSP manual:
http://www.bakerspride.com/pdfs/Y-600%20DSP%20%20Parts%20List%20U6051A%202-07.pdf
Their website went down for maintenance as I was doing this. But their phone number is on the website. http://www.bakerspride.com/
Thier manuals list is here. Note the price list for parts is at the very bottom block top of 3rd row.
http://www.bakerspride.com/manuals.asp
Thanks for choosing FixYa.
Kelly
Bakers Pride... | Answered on Feb 18, 2011
Bakers Pride Y-600 Gas Single Oven Logo
Popular Tags
47 questions posted
Top Bakers Pride Ovens Experts
Paul Carew
David Kirmse
David Kirmse
Level 1 Expert
David Spradling
David Spradling
Are you a Bakers Pride Oven Expert? Answer questions, earn points and help others
View Most Popular
Bakers Pride Ovens
  • Bakers Pride Ovens
Most Popular Question
replace thermostat bp y 600
  • Ovens
