20 Most Recent
Bakers Pride BAK-DS805 Gas Single Oven Questions & Answers
My oven when i close the flame goes off
If the oven will light and work with the door open but flames out with the door closed, you have the air input blocked somehow. I know some people line their ovens with aluminum foil, but you have to make sure that you have the air flow.
I have a bakers pride
Hi
There are conversion kits available that you can use to
convert your oven. Hope this helps...please post back for further assistance.
Daniel
Pizza oven bricks need to be changed
You must use a long crowe bar lift the brick and pull it out need the size of the brick to let you know how much and where to get it if it a 2inch thick they are no longer sold most lilkely it 1 1/2 inch
Door on my bakers pride y600 pizza oven
Theses are called 3/4 door busings and should be changed when you replace the left side door rod (complete)and are available from any parts depot that sells bakers pride parts
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
