20 Most Recent
Frigidaire GLGR331A Gas Dryer Questions & Answers
How do I test the thermal limiter?
You will need an ohm meter, and the know how to use it. Turn on your meter to resistance check, unplug one or both of the wires going to it. Place the two leads on each of the terminals. If you have an anolog meter (has a pointer that moves) when you touch them, the meter should move towards the opposite end. If digital, it should show some sort of reading around zero or so. If neither moves you have an open circuit, and the limiter is bad. Now if it's a thermistor, checking of this needs to be checked with a certain value at a certain temperature. Usually cheap enough to just change if you get a bad code or uneven or no heating.
11/10/2013 10:57:28 PM •
Frigidaire...
Answered
on Nov 10, 2013
Won't turn on
Hello 33bakerfamil - You may try and reset the washer by disconnecting the power to the unit for up to ten minutes by flipping the circuit breaker off and back on. Is the washer making a humming noise? If so, either the drain hose or pump is clogged and needs cleaning. Will the drum manually rotate (when it is not in use)? If it does not, then the drum could possibly be unbalance and/or have a broken shock/bearing. Other possibilities are: experiencing an issue with the door lock assembly, control board communication, faulty timer/pump, and damaged cord. Because it could be a number of any one of several underlying causes, I would recommend reaching out to an expert to properly diagnose and repair the unit.
Dryer will not heat
My guess is you probably got some lint on the ignitor and cause a burnout or a limit to trip. If you don't hear the clicking associated with the ignitor heating up and the flame sensor kicking it off then I would check to see if maybe a limit was tripped. On gas dryers when the limit trips the dryer will operate but simply will not heat up. I have a full page with service manual included
HERE If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Just hooked up my gas dryer. worked great thru 5
What did you do move it from one place to another place? You may have shifted the lint around and cause a limit to get tripped.
Here is the manual and moreA gas dryer has a burner assembly consisting of an ignitor, 2 coils, and a flame sensor. The ignitor does 2 functions. It lights the fire and confirms the fire is on like a thermocouple. When it is heated it holds in the coil. If the glowbar is not lit then the coils will not open. The ignitor must be heated to allow that. So if the ignitor and flame sensor is fine and the dryer works when cool but stops heating when hot I would say you need to replace the solenoids. If you need further help, reach me via phone at
Belt replacement
Make sure the belt is not twisted. Look for reasons why the belt might have broken. Pop the top with a putty knife and support it with a chain or twine. Remove the front panel and get the drum out. Inspect the center bearing and glides for wear. Clean up the dryer removing as much lint as possible the ribbed side of the belt goes to the tub. Move the idler with one hand and loop the belt onto the motor shaft with the other using the access panel behind the backside of the machine. Here is a video showing
how to and other stuff If you need further help, reach me via phone at
My dryer is making a
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
When turning dryer on, you
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The
Dryer is not TurningDryer Repair - The
dryer will not startheatman101
