20 Most Recent
Motion Computing LE1700 Tablet PC Questions & Answers
Motion LE1700 Tablet PC repair
If the tablet is turning on, but not booting into your os then there is most likely a problem with the hard drive. If the computer doesn't turn on at all then the battery or charger may not work.
Motion computer battery
If you want your problem solved then you should provide a detailed account of what is going on with the device.
Plugged in not charging
try a power adapter with higher amperage- 19 volts 3.5 or better amps works well, or you could have a loose power plug on the tablet, or a bad battery...
Tablet starts up and goes right back off
That almost sounds like a dead battery, or your battery isn't holding a charge. Have you tried using it while it is still connected to the charger? If you do have it hooked to the charger power and it stays on, it's a bad battery. If if does the same thing while plugged in, it's a problem with the power supply in the tablet.
