20 Most Recent
Solarcon Antron 99 CB Base Antenna - A99 Questions & Answers
How to mount cb antenna in a tree
alright you came to the right place.My wife doesn't want an antenna on the house so I stuck it in a tree. Here goes. First you nedd to get up in the tree as high as you can without falling or breaking any branches.This is how I did mine. My son and I got up the tree and set an antenna l bracket into the tree to set the antenna on. Then we set the antenna on it and secured it with metal strip banding ( you can get it at Lowes or home depot) About 2ft from the bottom of the antenna attach one end of the band to the treeand wrap it around the tree crossing over the bottom of the antenna. Now move up about 4ft and attach another band in the same manner you did on the bottom. Make sure you have enough coax and connect it to the connector on the bottom of the antenna . Connect the radio and you are set to go. that simple
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
