20 Most Recent
Samsung GT-S5300 Galaxy Pocket Questions & Answers
I've been playing my brother style and enter
You didn't indicate the type of phone. Using the google account registered on the phone becomes a problem since in nearly all cases the data connection on the phone was left OFF. You may know your account and password but the phone isn't connecting to the internet to confirm. You are now left with the only option of hard resetting the phone and obviously you will lose all the contacts and installed applications too. But that is not a problem. If you had synced your contacts to your google account, once you register into your account again, all your phone numbers will be available again. Always be syncing your contacts with your google account. Newer phones models can be recovered by a technician without losing anything.
My phone was blocked due to too many attemps to
It's unfortunate, but the only real way to correct this is to reset the phone.1. Power off your phone.2. Press your volume-up button, your home button and your power button till your System Recover Screen comes up.3. Scroll down to "wipe data/factory reset"and press the home button to select this option.4. A confirmation screen comes up. Scroll down to "YES - DELETE ALL USER" and then press the home button.5. Select the "Reboot System Now" option next and wait for your phone to reboot
User fault kernel panic upload mode
try this & good luck :)turn off your phone with hold the power button-----take battery out-----turn on again with press the power+volume up button, hold until samsung logo appear then release the button-----type *#9900# on call menu-----select "choose debug level" then switch to normal.
I fogot my password and my email addess
If you've forgotten your pattern or password lock for your Samsung Galaxy Pocket GT-25300, you may need to do a hard reset. Here's how!
Simultaneously hold down the volume up button, the Home button (the button in the center below the screen) and the Power button.
Keep holding. After a few seconds the logo Samsung Galaxy Pocket; then release the button.
Check your phone boots in recovery mode.
Select "wipe data / factory reset". Use the volume rocker to highlight this option and confirm the selection by pressing the Home button (in this mode, touching the screen does not work).
Select "Yes - delete all user data" in a similar manner on the following menu.Wait a few seconds while the full reset. The phone will return to the first menu.
Select "reboot system now". In a few minutes, the phone will boot normally without asking data from your account.
is its Helpful plz click on helpful
