20 Most Recent
Pioneer DVR-112D DVD RW Dual Layer Burner Questions & Answers
PIONEER DVD-RW DVR-112D driver is not installing. Says Available target is not found
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
I can not burn audio
you need to provide a little more info please. What windows O/S are you running. What cd creation package are you using. Has it only just stopped working? never worked? Please give as much detail however small. Your question at the moment is like giving a suspect description and saying "the mugger had skin". :-)
My DVD-RW has stopped burning.
Try uninstalling the burner using the Device manager and letting Windows reinstall the drivers on reboot.
Right click on My Computer then Properties > Hardware > Device Manager > click on the '+' next to DVD/CD ROM drives, right click on the drive and 'uninstall'. Reboot and Windows will re-install the drive.
не читает dvd
Boris
Is this drive a new addition or have you had it and this just started?
Have you changed your OS?
Make sure you have all of the service packs for your OS.
If you have 2 optical drives try setting this 1 as slave and the other as master.
Update your firmware to the latest version at this link.The 112 series is about half way down.
Bob
http://pioneer.jp/device_e/product-e/ibs/device_e/dev00001r_e.html#firmware1
Laser burned out
If you are convinced that the laser burned out, the most you can do is to buy a new drive. It's possible to buy a new diode and replace it, but it's highly not recommended as it might not be compatible and can be very dangerous.
It dosn't recognize disk is in the recorder
If it has never worked, you should contact the support from the store you brought this in, or contact the manufacturer for more about its warranty, if it has one. Make sure that the cables are plugged in properly, the discs are working on another drive, and see if it needs any drivers.
My pioneer dvdr112 will play dvd/cd fine but nero
Some things to think about, no all products (such as Nero or Roxi are set to be compatible with MS compatible products, Pioneer is a goos product but may noe be compadible with Roxio, try Windows Media Player this will tell you if it is Roxio or something else
My DVR-112D can't read CD-s, but no problem with DVD-s
- Click Start and then click All Programs.
- Click Accessories, and then click Run.
- Type regedit, and then click OK.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
- In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
- In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
- On the Edit menu, click Delete.
- When you are prompted to confirm the deletion, click Yes.
- In the right pane, click LowerFilters.
Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
- Exit Registry Editor.
- Restart the computer.
My pioneer dvr-112d is not appearing to be connected
If your pc is not finding the drivers you can try to go to the manufatures web sight too look for them or it might just be a reg error ez to fix but let try the drivers first if you cant find them online plsz give me the manufatures name and moldel name or # to search.
