I hope this will help. It shows locking and unlocking ids while scanning and while in a bank.
Locking/Unlocking IDs
Contents
You can lock out IDs you don't want to hear such as telemetry, MDT's, dog catcher, etc.
To Lock out an ID while scanning, quickly press
L/OUT while the ID is displayed.
To Lock or Unlock an ID manually:
1. In Manual mode select
any channel of the bank you want to lock or unlock an ID in by entering the bank number and channel number (Ex: 001) then press
MAN to advance to the channel.
2. Press
PGM then
TRUNK to put the scanner in program and trunk modes. You will see the bank number (
0-9), list number (
0-4), and the list status (
ON or
OFF) on the 1st line, the ID# in the list (
0-29) on the 2nd line, the
ID on the 3rd line, and
bank tag on the 4th line (if programmed).
3. Press
TRUNK (each time) to select the ID list (
0-
4).
4. Select the ID# (
0-
29) by pressing
or
(or press and hold; faster) then press
L/OUT to lock or unlock the ID. An
L will appear to the right of the ID# if the ID is locked out.
5. Press
MAN to exit programming.
To Unlock IDs in a bank:
any channel of the bank you want to view the locked out IDs in by entering the bank number and channel number (Ex: 001) then press
2. Press
PGM then
TRUNK to put the scanner in program and trunk modes. You will see the ID list.
3. Press
FUNC then
L/OUT (each time) to view the locked IDs. Press
L/OUT to unlock the ID. The next locked out ID will appear.
4. Press
Note: You cannot unlock all IDs at one time.
