20 Most Recent Acer Aspire 5600 Series 5630-6951 Laptop Questions & Answers
2answers
ACCER laptop not ON
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
>27
7/17/2020 7:32:02 AM • Acer Aspire 5600... • Answered on Jul 17, 2020
2answers
Difficulty in playing dvd
#1. are you positive it has a dvd player?
#2. If so, you will have to have dvd player software like WinDVD or
Power DVD.
4/7/2020 7:06:53 AM • Acer Aspire 5600... • Answered on Apr 07, 2020
My Acer Aspire 5920 crashes
you just have to format the laptop for you to solve the problem
8/14/2017 9:00:43 AM • Acer Aspire 5600... • Answered on Aug 14, 2017
2answers
Acer Battery Power
may be this is an attack by some harmful viruses . i too experienced blue screens due to virus attack . downlaod avast proffesionl edition and install it (latest version availabel on katz.cd ) and scan computer at boot time ( avast only provides boot up scan ). otherwisw think of installing a fresh copy
8/7/2017 11:21:20 AM • Acer Aspire 5600... • Answered on Aug 07, 2017
2answers
How can i format my laptop?
u can format in progress install new windows
4/18/2016 6:28:15 AM • Acer Aspire 5600... • Answered on Apr 18, 2016
How do I scan documents.
You must use OCR to do that, OCR means Optical Character Recognition, first you must scan the hard copy and save it as TIFF format and run through OCR reader, take note that convertion is not perfect, you still have to edit words that are not read correctly. You can download OCR reader on this link: http://finereader.abbyy.com/?gclid=CK6C96aflZ4CFRgbawodiDZ2oQ
9/16/2015 6:21:43 AM • Acer Aspire 5600... • Answered on Sep 16, 2015
2answers
How to reset the bios of the Acer 5920?
you can reset the bios setting by removing the battery, you can also remove the jumper pin from the motherboard from pin1-2 to pin3-4 wait for 10sec then return to pin1-2
3/22/2015 4:09:07 AM • Acer Aspire 5600... • Answered on Mar 22, 2015
Locate ip address
To find your computer's IP address
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, type adapter, and then, under Network and Sharing Center, click View network connections.
  2. Select an active network connection, and then, in the toolbar, click View status of this connection. (You might need to click the chevron bf164617-11ac-4577-9d91-93f8f8f4aecc_40.jpg to find this command.)
  3. Click Details. Your computer's IP address appears in the Value column, next to IPv4 Address.
3/2/2015 7:06:58 PM • Acer Aspire 5600... • Answered on Mar 02, 2015
No sound speakers or headphones
try rebooting or go into settings of device. when you first start your computer press F8 that will give you options.
9/29/2014 7:59:42 PM • Acer Aspire 5600... • Answered on Sep 29, 2014
7answers
My Laptop says it's locked
There are a lot of Windows password revealers and crackers available, but I’ve found that Windows Password Recovery Tool is the most effective.:
it not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password
You can use the ISO to burn a boot CD. Follow these instructions:
1. Download ISO file from http://www.windowspasswordsrecovery.com Windows Password Recovery Tool
2. Burn to a CD using a CD burning tool such as Nero or Roxio or MagicISO
3. Insert CD into drive and reboot.
4. You may have to select an option in the BIOS to get the computer to boot from the CD.
Booting up and clearing a password takes a minute or two works like a charm.
8/8/2014 8:11:18 AM • Acer Aspire 5600... • Answered on Aug 08, 2014
Enter primary HDD user password.. pls....
You can get the HDD master password for your acer laptop from http://www.unlockbiosrecovery.com/Unlock_Acer_HDD.phpFor $20 they will email your Acer HDD master password and they guarantee it t to work. I use them monthly in my work repairing laptops.
7/3/2014 12:36:10 PM • Acer Aspire 5600... • Answered on Jul 03, 2014
How can I start up my Acer Aspire 5733-6410 in Safe Mode
Restart your laptop. After it shows acer logo..Press F8 multiple times... (preferably 3 to 5 times) a screen will show you multiple options.. Select Safe mode (this will be first option and then hit enter... It will show you your Window name (windows 7 / windows xp) press enter again and it will boot your window in safe mode regards, Bilal
6/15/2014 4:18:27 PM • Acer Aspire 5600... • Answered on Jun 15, 2014
How can I get my Acer Aspire 5733-6410 Laptop to Boot Up
Well not enough information , ALT PLUS F10 at the start logo Will send you to recovery factory mode work it out from there ,to what you want to restore
5/31/2014 4:59:52 PM • Acer Aspire 5600... • Answered on May 31, 2014
4answers
I need to format my
Hi
Which way have you tried to do the erecovery method
please add comment below explaining which way you did it
many thanks
5/27/2014 4:17:13 AM • Acer Aspire 5600... • Answered on May 27, 2014
2answers
Resource Conflict - PCI Network Controller in Slot 02
check for an update of bios on acer.com it will fix your laptop problem....
5/24/2014 8:41:33 PM • Acer Aspire 5600... • Answered on May 24, 2014
Mi acer 5610z no reconoce el cd-rom
Install CD rom softaware from acer website if it still does not work then it could be defective and you will have to replace it. sometimes, if you install incompatible software this happens too, in that case you will have to get your windows repaired.
5/24/2014 4:36:19 PM • Acer Aspire 5600... • Answered on May 24, 2014
Where is cmos battery in acer 5600
Disconnect the power cord from the laptop and remove the main battery. Open the laptop computer's screen and extend it as far back as it will go. Be careful not to stress the screen and cause any damage, but press it hard if needed.
  1. Press a flat head screwdriver under the front of the plastic bar lining the back of the laptop's keyboard. Pry the bar up slightly and hold it with one hand.
  2. Pry up the other side of the bar with the flat head screwdriver and fully pull out the bar. Keep its ribbon cord connected and set the bar on the laptop's screen.
  3. Remove the two Phillips screws securing the computer's keyboard. Slide the keyboard up and out to remove it. Again, do not remove its ribbon cord, and set the keyboard over the laptop's touch pad.
  4. Remove the four screws securing the cover plate over the motherboard and remove the plate as well.
  5. Locate the CMOS battery at the bottom-right corner of the motherboard.
4/27/2014 6:28:40 AM • Acer Aspire 5600... • Answered on Apr 27, 2014
Acer web cam not working last 2 weeks,model of lap top is:aspire 5630
Check your device manager for the imaging device ( webcam ) If not found, try booting into safe mode and give a look again in device manager. If you have any usb devices connected disconnect them If all of this do not work, you may have disconnected the webcam or could be bad. Hope this helps
4/9/2014 7:04:19 AM • Acer Aspire 5600... • Answered on Apr 09, 2014
Acer Aspire 5600 Series 5630-6951 Laptop Logo
705 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
tally 7 2 hangs upon start
  • Computers & Internet
