20 Most Recent
HP LaserJet M3027x MFP Printer Questions & Answers
The roller in the feeder has come out, I don't
I am not sure as to which roller you are talking about but please find below the solution.
!!!!DO RATE MY SOLUTION!!!Pickup roller replacement
Tip the device over on its rear side, with the top of the device facing you.
Rotate the bushings (callout 1) on each side of the roller upward.
Remove the left-side bushing by sliding the bushing to the left.
Slide the roller and shaft toward the left until they clear the hole in the right-side bushing, and then lift the right end of the shaft.
Slide the roller and shaft toward the right, and then lift the roller and shaft together out of the device.
This is for ADF (Automatic Document Feeder) on top of the printer.
Turn off the device and unplug the power cord.
Open the ADF cover.
Press the round blue button while lifting the green lever. Rotate the green lever until it stops in the open position. The pickup roller assembly should remain on the surface.
Remove the assembly, and then wipe the assembly with a soft, dry, lint-free cloth.
Replace the assembly, with the largest roller down, in the upright holder, and then press until the assembly snaps into place.
Make sure that both sides of the assembly are secured by the blue hooks.
Lower the roller assembly, and then close the ADF cover.
NOTE:
If jams continue in the ADF, contact a local HP-authorized service provider.
Plug in the device, and then turn on the device.
Error code FF09
User's manual should be a PDF included in your software install CD. You will probably want to access that next time.
Blank pages
Are you checked cartridge contacts left side of the cartridge bank, you can observe three flexible plastic shells representing the contacts to cartridge,, check them there is the problem....
HP M3027X - has 52.00 error code. We replaced the
1. Verify that the laser/scanner motorconnector and the ribbon cable fromthe ECU are firmly seated on the laser/scanner assembly.2. Verify that the laser/scanner motorconnector is firmly seated in connectorJ402 on the ECU. You might have toremove the main cooling fan to seethis connection.3. Verify that the ribbon cable installed inconnector J403 on the ECU is fullyseated. You must remove the ECU inorder to verify this connection.4. If, after checking the cables, themessage persists, replace the laser/scanner5. If, after replacing the laser/scanner,the message persists, replace theECU Replacing the ECU isn't pretty. If you haven't done it before, you probably should get someone that has.
Mfp 3027 is making a
If it is making a wah wah sound when printing, or grinding, the problem is the bushings on the lower pressure roller. Remove the fuser again and check the bushing on the driven side of the fuser. If there is a bunch of dust and you can see a visible gap between the shaft of the pressure roller and the bushing then that is the cause of your problem. If the printer has less than 150,000 pages on it, stop now and do not disassemble anymore of the fuser, see my tip
here, as the fuser is covered under an extended warranty by HP. Act quickly though as this warranty extension expires on June 30th.
Modem error 82
You can get an 82 error if you are trying to send a fax at the same time one is being received.
If that isn't the case for you, and power cycling the printer didn't help, you are going to have to log a service call.
The fax module may have to be replaced.
Sorry.
Can I scan from a
SMTP server means a mail server. You do not need that to share your scanner/printer with you MAC. All you have to do is to enable sharing the printer with a network and then connect to that network on your MAC, obviously through wi-fi.
FAX CONFIRMATION PAGE
Touch ADMINISTRATION then touch CONFIGURATION PAGES then MENUMAP and that will print a guide for you to look for FAX REPORTS and when to print them. You can also have a thumbnail put on a report
