20 Most Recent GE Zoneline AZ38H12DAD Split System Air Conditioner Questions & Answers
I have a AZ38H15DADM1 that works fine in heat mode
When setpoint is reach unit would shut off .
If you put the fan to the ON position it would run all the time and ac would cycle on and off depends on the temperature
4/2/2018 6:39:52 AM • GE Zoneline... • Answered on Apr 02, 2018
Compressor don't statr in heat
check your airflow. grills open, filter clean etc. typically when a unit runs once and won't come back on without a reset it points to a safety switch that is kicking the unit out. By cycling power you are resetting the switch until the next trip. Many times related to lack of airflow. If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
2/24/2018 12:36:13 PM • GE Zoneline... • Answered on Feb 24, 2018
I have 3 Fujitsu heat / cooling multi split
If it happens in heat it must happen in cooling. The indoor unit has nothing to do with if it's heating or cooling. You likely have 2 moving parts in the machine, the blower wheel and the swing fins. Turn swing option off, eliminate that. You get the rest... If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
6/4/2017 2:06:31 PM • GE Zoneline... • Answered on Jun 04, 2017
In the heat mode blows cold air heating element
There are a few different things that could cause the heater to blow cold air. I would suggest looking into the different parts of the heater that cause the heat to be generated. If any of those are bad, it would definitely cause this problem. If you aren't able to find the damaged part, you should talk to a professional to look at it for you. Hopefully you can get this figured out without too much trouble. http://www.getzschman.com/bellevue-ne-air-conditioner-furnace-repair-installation/
2/22/2016 8:46:19 PM • GE Zoneline... • Answered on Feb 22, 2016
Lennox 10hpb
change run capacitor on fan. or bad fan motor
9/5/2015 9:09:46 PM • GE Zoneline... • Answered on Sep 05, 2015
Why my heat pump only heat in emergency heat only,the condens is cutting off and on
It sounds like a maintenance issue with your heat pump, its clear that the unit is trying to run but one of the safeties is shutting it down trying to protect itself. most heat pumps are equipt with a High press lockout usually a manual reset ,a low press, cut out switch resets on rise of press automatically. Causes of LPCO Extremely dirty condenser coil or evaporator coil, Loss of fan on condenser, Low refrigerant charge. A competent Service man should be able to locate and correct this problem. A seasonal check up on the unit avoids these problems.
2/22/2015 1:07:32 PM • GE Zoneline... • Answered on Feb 22, 2015
2answers
I have a fairly new
This unit only has a warranty for 1 year. Have you followed the use and car instructions? If your looking to get the unit fixed follow the support link below and use the contact number for ge located on the right side of that page:
http://www.geappliances.com/service_and_support/contact/
Thank you,
Lee
10/20/2014 1:57:06 AM • GE Zoneline... • Answered on Oct 20, 2014
What does PF code mean on Amana PTAC unit?
I would assume that there was a recent Power Failure (PF) or that it may still have a power failure. Find the double pole breaker and turn it off and back on
12/5/2013 2:21:47 PM • GE Zoneline... • Answered on Dec 05, 2013
My PTAC a/c works fine but only the electric heat
please check the valve
11/5/2013 10:26:47 AM • GE Zoneline... • Answered on Nov 05, 2013
How do you get the external thermostat to control the unit
What is it doing now? If it works but not well it could be the postioning of the thermostat. Air flow around it must be plentiful and unobstructed. Ensure thermostat is connected to unit correctly. Using a power meter, check that you are getting power to the thermostat AND it is going back to the unit. Doesn't work if it does not send power back.
4/23/2013 12:11:15 AM • GE Zoneline... • Answered on Apr 23, 2013
2answers
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
11/30/2012 12:17:06 PM • GE Zoneline... • Answered on Nov 30, 2012
2answers
Short Cycling
COMPRESSORS HAVE AN INTERNAL T-STAT TO PROTECT THE WINDINGS ... SOME THING IS CAUSING YOUR COMPRESSOR TO RUN "HOT" THIS WILL KICK "IN & OUT" THE COMPRESSOR DURING COLLING OPERATION AND HEAT MODE (IF IT IS A HEAT-PUMP). 1ST THING TO EASILY CHECK IS THE CONDENSOR "OUT-SIDE" COIL. (CLEN BOTH WHILE YOU ARE AT IT). THESE FANS PULL THE AIR IN AND A BLOW OUT THE COIL .... ALL THE DIRT WILL BE ON THE INSIDE. 2ND THING IS THE FAN ITSEL OVER HEATING AN TURNING "OFF" ON ITS OWN "BUILT-IN POTECTION T-STAT". THIS WILL GIVE YOU THE IRRATIC OPERATION YOU ARE DESCRIBEING. I TEND TO THINK IT IS YOUR FAN MOTOR ... EASY TEST. TURN "OFF" EVERYTHING BUT THE FAN. SET IT FOR MANUAL "RUN ALL THE TIME" POSITION. THE FAN SHOULD NOT KICK OFF !!! IF IT DOES YOU FOUND THE PROBLEM. IF IT DOES TURN OFF IT CAN BE A WEAK CAPACITOR. UNITS VARY ON WETHER THE CAPACITOR IS FOR COMPRESSOR/FAN OR HAS A SEPERATE CAPACITOR FOR EACH. CAPACITORS ARE NOT EXPENSIVE. HOPE THAT CAN NARROW YOUR PROBLEM DOWN
9/12/2012 12:27:10 AM • GE Zoneline... • Answered on Sep 12, 2012
How to connect to my
carefully follow the below steps;
Turn off the circuit breaker that controls the air conditioning system. Turn the thermostat to the "On" position to make sure that all power is cut off and the air conditioner cannot accidentally operate.
Remove the cover of the existing thermostat and remove the colored wires from the terminals. Take out any screws that secure the thermostat to the wall, and remove the thermostat.
Mount the new thermostat on the wall. Feed the wires through the unit, with enough slack to allow you to make the new connections.
Connect the red wire to the thermostat terminal labeled "RH," "RC" or "R." The red wire carries the power from the transformer.
Connect the green wire to the thermostat terminal labeled "G." This controls the relay that controls the fan. Attach the yellow wire to the "Y" terminal of the thermostat. This powers the main control. Connect the white wire to the "W" terminal. This is the heating control wire.
Close the thermostat's cover and turn the breakers back on. Turn the new thermostat to the "On" position to test it and that would be all.
I hope the above helps. If it is not helpful, please let me know so that I may direct you further.....
Good luck.
2/25/2011 11:11:04 PM • GE Zoneline... • Answered on Feb 25, 2011
GE Zoneline AZ38H12DAD Split System Air Conditioner Logo
83 questions posted
Top GE Heating & Cooling Experts
vince
Alfredo Texmenistan
Level 1 Expert
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • GE Heating & Cooling
Most Popular Question
amana ptac ptc093a35aa blow heat
  • Heating & Cooling
