20 Most Recent
Dell OptiPlex GX520 PC Desktop Questions & Answers
I NEED SOUNDCARD OPTIPLEX GX520
if you are referring to the actuak sound card device, you'll need to purchase one, however, if you are referring to the sound card driver, you can go to support.dell.com, then click the link for drivers and downloads, enter your service tag and look under the AUDIO category to download the applicable driver for your sound card that is compatible to your operating system. hope this info comes useful
Cant show display
can you hear any beep sound from the pc?
if your desktop power coming on?
Dell desktop won't stay shut down
Here's a resource on Dell that might be of use:http://en.community.dell.com/support-forums/desktop/f/3514/p/19410137/19961690.aspx#19961690
After pc is on for awhile the power light blinks
It sounds as though your computers hibernation feature is malfunctioning, or your power setting are set to shut your computer off. If I were you I would attempt to disable both features, Go to Start in the bottom left, click on Control Panel in the Start menu, and then go to Power Options. Basically just tell it to never shut off any hard disks or the computer.
HOW dO I aDD memory?
It really depends on what you have now. Go to crucial's site
http://uk.crucial.com/gbr/en/ and use the scan computer tool and it will tell you how, if you can and the parts if possible.
Frankly this is the safest and surest way of doing this.
Now my problem my camputer can not open a any soang
You need to have software to do it. If you do not have MS media player etc then it will not play but there are many others that if yo look can be used for free.
So first look for media player, if there is no player then that is your problem. Do also check and make sure the music has either MP3 or similar as if it is not encoded properly it will not play.
Unlock bios
No such thing. If you want to unlock your BIOS so you can overclock the computer, the CPU must be overclockable from the factory. If the CPU is locked you can't do it.
AUDIO DRIVER WIN 7 32BIT
not much info but go to audio devices in device manager. right click for properities to find drivers. reinstall if needed or go to pc website and enter model/tag number when it displays drivers, pick the Audio files and download/install the drivers for your pc. you question is not specific enough for a specific solution
I want to reload
your fan might have problem buy a new one. your computer won't start if it is already at its maximum heat level.
