20 Most Recent
Dell OptiPlex 360 Desktop Computer Questions & Answers
Can't boot from cd
go back and put the first boot as the internal hard drive
when that is done , insert the cd in a cd unit and auto run the cd
what ever you have will download onto the pc hard drive
Start pc motherboard light on but not working
Try swapping out your power supply with one you know to be working. If that does not work, then it is most likely that the CMOS chip on the board is blown, which will mean replacing the motherboard. There is a small chance that the CPU or RAM may be at fault, bur that is far less likely and can be tested by swapping as with the PSU.
Repair hard drive
To repair a hard drive is a very expensive method.Better buy a new one.
No signal input
First, of course, make sure everything is plugged in properly and tightly. If that doesn't fix it try hooking up another monitor. If you have one. That will tell you if your monitor went bad or it's something with the computer itself.
System unit on but screen does not desplay
Hi..
Try to open the RAM from the device clean the RAM and slots then install it back and now check it..
still problem persists that might be problem with ur monitor resolution?? if its.. then check with another monitor.....
Hard disk is not decting
Check power and data cables. Right click on "computer" and go to manage, then disk management. Make sure drive is active and formatted as volume and not empty space.
