20 Most Recent
HP Deskjet 6980 InkJet Photo Printer Questions & Answers
Hp deskjet 6980 will not change to online.
Right click printer properties and select online. Start /settings /printers. Offline can also indicate a connection is not available - this occurs with demo versions of printer software. When the demo expires, the printer goes offline. The fix is to just use windows networking and shared printer.
HP Deskjet 6980 series - randomly printing out the
pls uninstall the printer driver from your pc, remove the usb core, turn off your printer and shut down your pc for about 10 min. then put on your pc reinstall your printer driver, if you have another usb cable change
HP Deskjet 6988 Printer
Hp printer properties best to do this with the usb attached. in the properties you will find printer name make model and setting go to settings and a list with links on depending on what windows you are using, there is auto shut down (2hr) etc on one of the drop lincs is standard and quiet mode. click to standers and save it should be out of that setting now. if still stuck use this link to fix problem with the printer.
HP DeskJet 6520 6620 6840 6940 and 6980 Printers Top Cover Open Message...
Wireless or Blue tooth capable
You may call HP Tech Support At toll free- 1-800-585-2494 and ask any technical question to hp support agent. you may also contact them via chat support by visiting:
HP Customer service . hope this will help you better.
Hp deskjet 6980 blinking lights
ok so for this situation you have to do a cold reset, and by this you have to go ahead while the printer is still power on, disconnect the power cord in back of the printer, and wait for about two minutes. power on the printer if printer still has the blinking lights then go to step 2.
step 2-after this check the printer if light are still blinking, then your going to remove all printheads, remove paper, and then unplug printer power cord from printer and also from the wall outlet, wait for 20 seconds, then power on the printer, wait for light to flash then install the printheads, put paper, and press the resume button.
*** always connect your printer to a wall outlet never to a power strip, the power strip robs some of the power from the printer***
and this should fix the problem if it doesnt then the carriage might me malfunctioning . hp recently did a recall on some printer with the 6940 and some of the 6980, that the carriage broken.
Hope this help!
Upside down orange light bulb on the right side is
When the camera is connected correctly, the Connection light is
illuminated. The Connection light blinks green when printing from the
camera. If the camera is not PictBridge-compatible or is not in PictBridge
mode, the Error light flashes.
Bottom of words not beng printed
Try going in the printer menu on the printer and select "clean printer heads". Other wise it is not economically worth it to fix . Buy a new Printer.
Why is printing leaving off bottom portion of
It is happening becasue your printer head has become faulty, you need to replace it, how ever you can try cardrige alignment and see if that works, but if that does not work,then there is only one solution to this problem and that is print head replacement.
HP Deskjet 6980 won't print.
Printers often go off line for no reason. It can be genuinely off line or the pc is just not seeing the printer anymore To put it back on line all you need to do is open the print queue (double click on the printers icon in printers devices/ printer and faxes) go to File and in the drop down list it will say "Use printer Offline or Use printer online. click on it and if the pc is seeing the printer if will change and the printer will then start up and print. If this does not work then check your cable to the printer or your network connection to reestablish the connection.
