20 Most Recent
HP vs19 (Silver) 19" LCD Monitor Questions & Answers
Describe your vs19 (Silver) 19"
the monitor is bad.? does it work with a flashlight pointed at the screen? yes, then the CCFL tubes inside are bad,
or the main board, HV inverter section bad.
so replace it.
HP does not make books on monitor repair or disassembly .
remove the base and base bracket first.
then all screws you see, it then splits. all ascess covers off too first, that can hide screws.
it is not the diodes
#1 all time fail is CCLF here. never seen on this old not dead.
all are now, 20,000 hours and BAM dead.
that is why LED was invented top stop the BAM.
HP L1906 flat monitor
why not test the monitor on another PC
works there good.,
if not the monitor is bad.
can be monitor bad, cables bad, power pack if fitted bad.
test it on another PC.
win
if bad monitor start a post how to fix a bad monitor (endless answers)
When I start the computer
If this monitor (HP w1907) is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
How do you dim monitor brightness
This can be done in the menu on the monitor. There should be a button that says menu. push that and sub menus will come up. There should be a choice for brightness. Most of the selections are then adjusted using the volume buttons Up or Down.
Where is the fuse in the monitor
Hi ThereThe Monitor setting you set through the computer, may you select the sleep mode or hibernate. Basically there is no any external fuse. so don't find that one.Thanks http://pacificbits.ucoz.com/
White screen all the time
take it to any Monitor technician or service. It has image output problem in it or a IC is damaged.
My 2007 HP monitor (vs19e) began giving me problem
I am sorry to hear regarding the trouble. This is a common problem with HP monitors and we have discussed the same in length in many forums and blogs. There are 2 main reasons for the same :-
1. There is dust accumulated inside the Menu button which makes a short
circuit and so you repeatedly get the Display Menu. You can resolve this
by opening up the monitor panel and blowing away the dust with a
compressed air can. Do NOT use hot air blowers. Also try to clean up the
circuits with a very soft dry cloth.
Caution: First unplug the monitor and leave it without power for 2-3 hours before performing above procedure.
2.
This is a common issue that happens when a particular IC (integrated
circuit - Chip) goes bad either because of manufacturing defect or age.
So if step 1 does not resolve your issue than the only option is to get
the monitor replaced from HP if it is under warranty. If it is not in
warranty don't even think of getting it repaired as that will cost you
much more than buying a new monitor.
To open the monitor, you need to unscrew the screws on the back side or they might be hidden under some panel.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Screen is black and power button is blinking
You need to try it with another PC first to make sure it is not the PC problem. This model is known to have bad caps and bad lamp assemblies.
See my pictures here:
http://s807.photobucket.com/albums/yy352/budm/HP/HP%20VS19D/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
I can not ge rid
Press and hold the menu button for about 10 seconds.
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
Hope this helps. Any vote will highly be appreciated. Thanks =)
The screen does not seem to have any power at all
More likely to have failed power supply due to bad caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Sometime screen not still pixel
this problem can happen if the vedio cable is loose or bad. take the the back off panel get the vedio cable make sure its pluged in tight if it is and you still have the problem price and consider replacing the cable
