20 Most Recent HP Pavilion dv1000 Notebook Questions & Answers
2answers
RedBull disaster
Dear Firas
Try the following guide (For the Keys)
http://www.laptoprepair101.com/laptop/2007/03/20/key-fell-off-keyboard/
There are no guides from HP for the keys available for the DV1000 but this guide will be more than enough to help you through this one in order to remove them. Its completely the same principle
In order to reach the inside of the laptop you definetely need the User/Service Manual of the Laptop with instructions on how to take it apart, which is found here:
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
As i see it beneath the keyboard the IC's of the laptop (motherbard's/memory/wifi/ sound card etc) should be cleaned with clear alcochol or near clear (95% and upwards) with a soft brush (ESD if possible)
Then let it dry either (If you do your previous method take it easy though,not to close, as some chips at temps >85 degrees celcius could be damaged.)
Please remember to ground yourself first and if possible wear antistatic gloves to protect the IC's from damage from electrostatic discharge. Again before you do this remember to remove any AC cables and the battery.
Regards
Please don’t forget to rate this solution if it was helpful, it keeps us going!
1/2/2023 9:11:32 PM • HP Pavilion... • Answered on Jan 02, 2023
4answers
I have hp windo7,& i want 2 known how
The below tutorial is a guide for doing that. You can follow the steps and get the question solved -
How to Convert YouTube to MP3?
YouTube to MP3 converter is not a must to complete Youtube to MP3 conversion. Instead, all you need is Leawo Free YouTube Downloader and its sister program called Leawo Free FLV Converter. So converting YouTube video to MP3 generally includes downloading Youtube video and converting the downloaded YouTube video to MP3, since YouTube video is FLV video on internet.
The former is a free YouTube downloader, which can download YouTube videos and other online FLV vidoes for free while the latter functions as an FLV converter which can convert YouTube to MP3 and many other popular video/audio formats. So use these two free programs, we can freely convert YouTube video to MP3 easily.
The following tutorial demonstrates exactly how to download YouTube video from YouTube and convert the downloaded YouTube video to MP3 within just a few clicks.
Step 1: Launch Leawo Free YouTube Downloader and type YouTube URL in the address bar.
screenshot1.jpgStep 2: Click settings icon to select MP3 as the target output format in "Auto Recording" tab in the pop-up window.
screenshot2.jpgStep 3: Select one YouTube video you want to download, click "Video" tab to check the YouTube video downloading progress and watch it in the built-in FLV player at the same time.screenshot3.jpgStep 4: When the YouTube video downloading progress reaches 100% and a yellow smiling face appears, Leawo Free FLV Converter pops up and converts the downloaded YouTube videos to MP3 automatically, showing the ongoing YouTube to MP3 conversion progress.
4/13/2022 1:43:21 PM • HP Pavilion... • Answered on Apr 13, 2022
4answers
DV1000 won't power up
This sounds to me like a motherboard issue, you could try going over all connections with a multimeter to see if any are broken. I would suggest to try and replace the board that ill fix it.
- John
12/16/2020 10:42:49 AM • HP Pavilion... • Answered on Dec 16, 2020
Starts burning DVD, it takes like hour and a half
What program are you using to burn the DVD?
Are you SURE that you have a DVD-R or DVD+R drive? Go to the Hardware Profile to be on the safe side and click on the CD/DVD icon to get the details
5/8/2019 7:15:05 AM • HP Pavilion... • Answered on May 08, 2019
Hp pavilion dv2000 internal micro phone drivers free download
I dont know exact model of your dv2000 hp laptop is, there is many versions of them (as an example HP Pavilion dv2401tu). Microphone drivers are part of the sound driver package. Suggest if you are running 7, go for the vista drivers. 7 32bit, vista 32bit drivers. 7 64bit, vista 64bit drivers. Windows update is another option for finding sound drivers for the microphone.
2/18/2018 4:38:33 AM • HP Pavilion... • Answered on Feb 18, 2018
2answers
Whirring sound on receiving end of skype
Microsoft are the problem, you need to have the same version of Skype on both machines.
2/11/2018 1:23:46 PM • HP Pavilion... • Answered on Feb 11, 2018
I have HP Pavilion dv1000 PC Notebook with 6GB of RAM and the processor is of Intel Celeron. Could I upgrade the processor and if possible to intel core?
there is no gain with the processor. no full models stated, just the dv1000 (it has a full model and p/n stated on the service tag. also you cant switch from AMD to intel, or the reverse. (cpu swap) tell why you need more speed? To t do what, that the above , can't to? a SSD hdd is the only sure fix. for speed here. (vast ) for speed here. IMO computers can do millions of things (apps) name just one , that you use that fails, or runs too slows. thanks for any answers to simple questions.
2/4/2018 1:51:10 PM • HP Pavilion... • Answered on Feb 04, 2018
2answers
What technical problem would cause the internet
You may need to update Flash Player.See my tip here: http://www.fixya.com/support/r6775220-not_able_play_youtube_videos
1/30/2018 6:20:57 PM • HP Pavilion... • Answered on Jan 30, 2018
About a year ago I
WHAT OS? XP? learn to use the control panel. (more later) the special keys like this can fail for 3 reasons (get it serviced)?
  1. bad hp keyboard driver, (or wrong one, or missing)
  2. virus infecttions (or worse root kit attacks)
  3. bad key.
click start. click control panel see sound? now click tab sounds in the top roller button , pick no sounds (bingo all sounds gone) error sounds and all or pick any sound seen there, and make it go dead, or change it to any thing, (endless, choices) even sound of silence. is possible like this , nosound.wav. or to pindrop.wav
5/10/2017 12:43:57 PM • HP Pavilion... • Answered on May 10, 2017
2answers
Zoomed into my screen and cannot zoom out
If you are referring to a web page, holding down the control key while pressing the + key will zoom in, pressing the - key will zoom out.
1/25/2017 5:53:16 PM • HP Pavilion... • Answered on Jan 25, 2017
I wana install audio driver for vindow 7
DL the driver and install it.
5/18/2016 9:24:20 PM • HP Pavilion... • Answered on May 18, 2016
5answers
I upgrade my hp dv1000 os to windows 7,now it has
Try this:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&os=228&product=435618#N646
1/11/2016 6:14:59 AM • HP Pavilion... • Answered on Jan 11, 2016
4answers
Windows 7 hp audio hp pavilion dv1000 drivers i
Sir, i have HP Pavilion dv 1000 (XP operating system). Recently, i upgrade it by Window 7 but Now audio driver is not working properly now. pl suggest to solve it.----- pratik
9/15/2015 6:29:08 AM • HP Pavilion... • Answered on Sep 15, 2015
3answers
Audio deriver for windows 7
Drivers for Windows 7 may be included in the operating system, distributed via Windows Update hpweb_1-2_exit.gif, or downloaded from HP. Please note that drivers for Windows 7 are available for select models only.
If upgrading from Windows Vista to Windows 7, many drivers installed on your PC may already be compatible with Windows 7. You may need to obtain new drivers if the previous drivers are not compatible, or if you perform a custom installation and reformat your PC.
or u can contact the link below for more detail and support
http://welcome.hp.com/country/us/en/mda/windows7/upgrade/update_drivers.html
8/20/2015 3:19:58 AM • HP Pavilion... • Answered on Aug 20, 2015
How to burn dvds
How to burn a DVD-Video Disc with Nero Burning ROM /> /> /> Alright, I know that many of you may say that there are plenty of DVD burning progs out there and that if I do a guide like this I should cover all of them. But I only got Nero and many users are asking me about how to burn a DVD-Video with Nero, so that's why Nero is the one for the guide.
This guide is supposed to be used by people that have created the compressed DVD files using DVD Shrink and now they don't know what to do with them or everyone that wants to see how to create a DVD-Video. Remember that for the DVD Decrypter guide you don't need Nero, as DVD Decrypter can burn the ISO file itself. Anyway before start reading this guide keep in mind that it is for use with DVD Shrink or other program that creates .IFO and .VOB files. Don't use it to burn files or mp3 in your DVD, for this you need to select a DVD-ISO disc.
Of course, Nero Burning ROM is a commercial program and we don't have it available for download. Instead you can get a trial version here.
/> /> First of all I make clear that I use version 6. If you have an older version that supports DVD (I think all the versions after 5.5.x.x) then the process is the same. Please make sure you start Nero Buring ROM I show here and NOT the Nero SmartStart. /> /> The new complication comes up. If you see a Wizard close it (there must be a button down right which says Close Wizard or something). Open the pull-down menu I show and select DVD.
NOTE: If there is no pull-down menu then your version does not support DVD.
/> /> Select DVD-Video (1) from the list. Then just make sure the settings (2) are the same as shown here. Then click on the Label tab. /> /> Here just put the label that you want your DVD to have. (It's the name that you see before your drive's letter every time you go to My Computer). After that click New. /> /> At the left of your screen you see the folders of the DVD we are going to burn. Notice the VIDEO_TS folder is red. Double click to open the VIDEO_TS folder. /> /> At the right of your screen you can see your hard drive. Browse to the folder where you have your DVD files (the files that DVD Shrink created). /> /> Select all the files. I repeat: ALL the files. /> /> Now drag and drop ALL the files you selected at the step before into the VIDEO_TS folder we opened before at your left.
IMPORTANT: People keep asking me that. Yes you put ALL the files DVD Shrink or other program created into the VIDEO_TS folder. The AUDIO_TS folder remains empty.
/> /> This is how Nero should look after all this. Note that the bat at the bottom should be all blue, or with just a little yellow where it finishes. Now click the burn icon that I show with the arrow. /> /> Here select just Write. Put the write speed for your media (for slower media like here, Nero reduces the speed from 4x to 2x, nothing to worry about) and finally click Burn!
Wait for it to finish and you will have a very nice DVD-Video disc!
6/17/2015 9:18:24 AM • HP Pavilion... • Answered on Jun 17, 2015
I cant access my upper case symbols
Hold down fn key
6/7/2015 1:59:40 PM • HP Pavilion... • Answered on Jun 07, 2015
HP Pavilion dv1000 Notebook Logo
1,303 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
burn dvds
  • Computers & Internet
