Download the App "AppCleaner.app"
Drag your Yahoo app to the "AppCleaner" icon
It will find all the associated files connected with the Yahoo item. Then just delete.
But.... Your machine looks like it might be in need of a full update?
Use this tool to see if your Mac can handle a Newer OS X.
Mactracker
This will give you all the tech info on your Mac
If Maverics is acceptable and you have say 2gb of RAM!
Then, Download the free Maverics OS X first.
Prepare an external USB Hard Drive (or Partition)
Try doing a full Clone Backup with CCC to the External HD
When finished Prove that the Clone is Bootable.
Use Option Key on Reboot. If OK
Use Drive Utility to Erase Internal HD ready for a clean install.
Then install a new clean OSX10.8 (Maverics) to get your machine almost up to the latest with a cleaned up pristine Mac HD.
Use Migration Assistant to return only the data files you want or just drag the "User" folder across by hand.
(Migration will bring back the Yahoo Software)
Mac Backup SoftwareOS Mavericks 10 9 Download
Is you computer connected to your route via an ethernet cable? If it is, check the port on the router to see if the connection light is glowing. Next, check you network settings and set the "Configure IP Address" to be "Using DHCP". This will also the router to allocate an IP address and settings to computer. Now see if you can access the internet.
Snow Leopard Support
Mac Basics Connecting your Mac to the Internet
Take a Screenshot of Entire Screen:
Hold down Command Shift 3
Take a Screenshot of Specific Area:
Hold Down Command Shift 4 -- You will see the cursor change to a Cross hair, Right Click and Drag over desired area, Let Go and screenshot will appear on Desktop
How To Take A Screenshot of Specific Window:
Select Window.
Hold down Command, Shift, 4, Space Bar - The selected screen will show a camera icon, Click on the Camera icon and the screenshot of the individual window will appear on your desktop.
Link to Video Below.
5 more Mac keyboard shortcuts that make computing even easier Cult of...
The disk might not have a working OS on it.
It you have successfully run the disk utility the disk probably in full working order. I think that the OS on the disk is either missing, corrupt or not compatible with the computer you are running it on.
Apple stopped supporting OS X 10.5. Upgrades are only $20 to 10.7.
If your Mac has 10.5, Lion, 10.7, is probably as high as you can upgrade. I would check either eBay or Amazon, as I've seen Lion disk sets selling for less than $5, then $4.95 shipping (or less on eBay).
All the best to you,
Kerry Hostetter
The issues are related to the drivers and the network security .. you need to install a proper security and setup the network properly for sharing purpose.
Call 1-877-805-1027 for expert help.
Did you check hard drive space? You drive may be running out of much needed free spaces. You can check by About This Mac through Apple Logo. Also I would recommend to run Disk Utility Verify/Repair disk in order to fix any error on the drive. You should download Stellar Speedup Mac software to clean & optimise Mac hard drive for free. You can remove plenty of junk data from the startup drive. You can download from here - Stellar SpeedUp Mac
Try to keep at least 25% of hard drive free for OS X operations.
must use system disc. Cannot upgrade across platforms. must use 10.6 disc then update software from there. There is no way to go from 10.5 to 10.6 without installing 10.6 from disk
you need system disc, cannot upgrade os with update software. Must have system disc to upgrade to next OS.
Can get 10.6 from apple or ebay or amazon or maybe someone on craigslist.
try booting with disk select option.
hold down option key and power up. Try resetting pram.
Look up key commands on apple support.
Try safe boot with holding down s key
etc....
cannot dl full version. Only updates. If you have 10.4 and want 10.4.11 you can dl it no problem. If you have 10.4 and want to go to 10.5 or 10.6 you need system disk.
10.5 and earlier not available from apple.
can be found on ebay and amazon and craigslist.
10.6 and up available on apple.com
