20 Most Recent Apple OS X 10.8 Mountain Lion Questions & Answers
Hey, If you have the problems with your mobile app promotion, then I can help you. I'm a representer of marketing company. You can buy google play installs in our service. This service is considered as one of the best app marketing services in the Internet.
Apple OS X 10.8... | Answered on Aug 17, 2018
Sounds like it might be a codec that is not included in the OS or the applications you have tried. Can you try VLC player? It's one of the most versatile media players around and plays almost everything that I've come across.
Apple OS X 10.8... | Answered on Feb 20, 2018
Hi Rachel,
In order to sync your Notes between your Apple devices, please use the following steps:
  • Go to your iCloud settings and sign up for an @me.com email address.
  • Once you have an @me.com email address, write a note in the Notes app on your iPhone.
  • Go to the iCloud website and open up the "Mail" application
  • Underneath all of your email folders (Inbox, Sent, etc.) there should be a folder called "Notes"
  • Open that folder and read your note!
Apple OS X 10.8... | Answered on Aug 29, 2016
Tip
How to change where screenshots are saved on Mac?
Step 1: Search for Terminal in Spotlight Search in the top-right menu bar.
Terminal App
Step 2: Open Terminal and type the following command: defaults write com.apple.screencapture location ~/Documents/Screenshots
Step 3: To apply the changes, enter the following command: killall SystemUIServer
That's it. If you entered the commands successfully, your screenshots will now save to a Screenshots folder within your Documents. Make sure to actually create the folder before applying the changes through Terminal though. Also, you can type any directory that you wish to save screenshots to, as it doesn't have to be ~/Documents/Screenshots if you would prefer something else.
on Jun 26, 2015 | Apple OS X 10.8 Mountain Lion
This is very easy and can be done two ways.
1. Connect your iPhone to your computer and sync the photos:
iTunes Syncing photos
how do transfer photos from my iPhone to my iMac
2. You can configure both your iphone and computer to sync the photos over iCloud.
iCloud Set up My Photo Stream
Apple United Kingdom iCloud All your content on all your devices
Apple OS X 10.8... | Answered on Nov 26, 2014
I had this issue. It is related to the Mac accounts where replaced my iCloud.
Going in to your Settings, and remove your account.
It require flash. In Safari, if you want to watch a video that requires flash, you must double click.
Apple OS X 10.8... | Answered on Oct 05, 2014
just go to software update in the apple drop down menu. Cannot update across platforms. Must be either 10.8 to 10.8.1 or 10.8.2 an so on but not from 10.5 to 10.6
Apple OS X 10.8... | Answered on Jul 25, 2014
must have system disc. May need to update firmware. Cannot get full os via download from internet
You would have had to add your iCloud account details when you configured your iPhone to enable the backup. To check that your data exists, go to the following URL and login:
iCloud
Here you should be able to see your data.
Assuming it has been backed up, go to your Apple computer "System Preferences" -> "iCloud" and select the data that you would like to keep in sync.
Apple OS X 10.8... | Answered on Jul 02, 2014
Go to open iCloud in preferences and enter the same username and password as your other devises. You will also find a number of options allowing you to select what data you would like to backup/share over iCloud.
Apple OS X 10.8... | Answered on Apr 25, 2014
Trying to run OS X 10.8 on a computer with an Atom and NM10 chipset? Should be OK as long as your CPU is one of the 64 bit ones. Try the latest chameleon package and build a boot USB stick with kernel patcher module is installed - 10.8.2 should install fine.
Apple OS X 10.8... | Answered on Jan 27, 2014
Possibly because you have not asked a direct question.
Apple OS X 10.8... | Answered on Dec 07, 2013
you simply cannot "uninstall" mountain lion just like that... You need to accept this like 20 times before it will be preformed. So I'm guessing you mean something else than "uninstalling" mountain lion?
Perhaps you have just changed a setting so the "gray start-up screen" is no longer visible. You can change this in your settings screen, at "users".
Apple OS X 10.8... | Answered on Nov 22, 2013
Greetings . . . Lesley - they don't exist. Seriously. Apple has decided to store the OS on a 'hidden' partition in case a restore is needed. Also, if the drive is replaced the EFI has an option to download and install the OS from the internet. There are various schemes (unsupported by Apple) to build a bootable CDROM from data on that partition. The other approach that you can use is to purchase Apple MacOS Server of the same version. This will come on a DVD. I'm considering this option myself . . . .
Good Luck
Mark
Apple OS X 10.8... | Answered on Nov 06, 2013
Lion, Mountain Lion, and Mavericks (10.7, 10.8, and 10.9 respectively) do not come on a physical CD or DVD. They are downloaded and installed through the Mac App Store.
After installing 10.7 or later, a 'hidden' partition is created on your computer that serves the same function as the physical discs did in earlier versions of OS X (10.6 and earlier), giving you access to Disk Utility, Install OS X, Get Help Online, and other functions that previously were accessed from a physical disc.
If for some reason the hard drive is damaged or the Recovery Partition is otherwise inaccessible, you can access the same utilities over the internet using Internet Recovery.
One can, however, create a bootable flash drive as a physical backup of your Recovery Partition using Recovery Disk Assistant.
All the information on how to access Recovery Partition, Internet Recovery, and Recovery Disk Assistant are available from the following articles:
OS X: About OS X Recovery
OS X Recovery Disk Assistant v1.0
Apple OS X 10.8... | Answered on Nov 05, 2013
There is no easy way to "downgrade" Mac OSX from 10.8 to 10.6.. You would have to find a 10.6 installer and cleanly install on the harddrive, which would delete the apps you are trying to use. Maybe a different way of looking at this is figuring out A) How to make your current apps work on 10.8 or B) Are there any new apps that can accomplish the same tasks as your old apps.
If you post the apps that are giving you issues maybe we can help find you a better solution.
Apple OS X 10.8... | Answered on Oct 20, 2013
How long does it take to lose 1/3 of its battery? What stuff are you doing? Internet browsing? Watching videos? ... And are you using a recent Macbook Pro, or is it an old model? Kinda hard to answer without any of this info.
Old Macbooks have crappy batteries that only last a couple of years. If you're not doing anything crazy and it still depletes quickly, you should consider buying a replacement battery.
Apple OS X 10.8... | Answered on Jan 29, 2013
If your computer has OS X 10.4 installed on it, it's likely that you have a PowerPC processor. Apple used these for years before switching to Intel processors in 2006. The highest version of OS X that you'll be able to run on a PowerPC Mac is 10.5 (Leopard). You will not be able to install Snow Leopard, Lion, or Mountain Lion.
Easy way to check if you have PowerPC or Intel is by clicking on "About This Mac" in the Apple menu (top left of your screen).
Apple OS X 10.8 Mountain Lion Logo
46 questions posted
Popular Products
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
OS Apple
  • OS Apple
Most Popular Question
apps run new os revert
  • Computers & Internet
