20 Most Recent HP LaserJet 4600 Printer Questions & Answers
HP 4600 print cartridges won't pull out. Seems like something has locked them in. Any suggestions?
Hello Mitch, The problem with the HP laserjet 4600 (cartridges won't release to be removed) is that the plastic cartridge lock lever located on the right side has broken and will not release any cartridge at all unless the side is taken off and you can move the lever by hand. This cheap plastic locking arm does all 4 cartridges at once.It is not exactly an easy fix and is very patience testing! Your printer needs to have a tech replace this locking mechanism. Good Luck! Rich Lilja
2/2/2018 1:55:45 AM • HP LaserJet 4600... • Answered on Feb 02, 2018
Says add paper...paper is full. Also is not deleting document in queue
It may be asking for a certain type of paper (heavy paper, labels, letterhead)
8/8/2016 7:47:42 PM • HP LaserJet 4600... • Answered on Aug 08, 2016
Error code EI0 1
EIO 1 is the port in the back of the printer for a JetDirect Network Card, or for the External Hard drive. Pull the card out of the slot (turn off the power first) then turn on the printer to see if the error went away. If so, you need to replace the item you removed.
7/20/2014 4:58:51 AM • HP LaserJet 4600... • Answered on Jul 20, 2014
4600 hp printer red stripe
Defective Magenta Toner Cartridge...replace it
7/20/2014 4:53:59 AM • HP LaserJet 4600... • Answered on Jul 20, 2014
Hp color laser jet 4600 57.40 error
57 indicates a printer fan error has occurred the .4 points to the formatter fan (F1) is bad. Connector J1004. Voltage should be 24 VDC between pins 1 & 3. If it is, then replace the fan, if it isn't, replace the DC Controller PCB.
7/20/2014 4:51:56 AM • HP LaserJet 4600... • Answered on Jul 20, 2014
Why do I get 3 groans during calibration accompanied by a 51.2m error ?
51.2 is a laser error. there should be another number after the 2, 0 = black laser 1 = cyan laser 2 = magenta laser 3 = yellow laser. The groan is most likely the polygon motor has lost its lubrication and may just need to be cleaned and re-lubricated. You can also try reseating the connectors from the lasers to the DC controller PCB...
7/20/2014 4:45:16 AM • HP LaserJet 4600... • Answered on Jul 20, 2014
Error 49.4c02
Disconnect any network or usb cables from printer and try to restart. If printer will restart and comes to ready you need to update the firmware. If you still get the error then either the memory on the formatter is bad, the firmware on the formatter is bad or the formatter itself is bad.
4/20/2014 5:37:57 AM • HP LaserJet 4600... • Answered on Apr 20, 2014
51.XY X Description: 1=beam detect error 2=laser error *** Y Description: 0=black *** 1=cyan 2=magenta 3=yellow Replace the black laser assembly !
3/16/2014 12:48:44 AM • HP LaserJet 4600... • Answered on Mar 16, 2014
0answers
0answers
Reset ink levels
For resetting the toner levels, cartridge memory chip has to be replaced. Memory chip was mounted beside of the each cartridge & its easy available in the local market.. For better idea pl see the snap.. 0d92125a-9dce-43c8-85d7-68feec4f888e.jpg
6/21/2013 11:24:28 AM • HP LaserJet 4600... • Answered on Jun 21, 2013
0answers
Making noise then displaying error asking to turn printer off
Just we cant judge reading the sound if we hear the sound we can say the fault, any how check fuser assembly seated properly or not? open side doors then observe where you are getting the sound..
2/2/2012 2:20:49 PM • HP LaserJet 4600... • Answered on Feb 02, 2012
Error Code 51.2 C on an HP 4600
This is a laser error. I found this directly from HP's website. Here's your fix:
  • Press the green c00224695.jpg (Select) button to continue.
  • Turn the printer off, and turn it on again.
  • Perform a cold reset.
    1. Turn on the printer.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the c00224695.jpg (Select) button.
    4. Continue holding the c00224695.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the c00224695.jpg (Select) button when the Ready, Data, and Attention light are on steady.
    6. The control panel will display SELECT LANGUAGE .
    7. Press c00224697.jpg (Down Arrow) button once. The control panel will display COLD RESET .
    8. Press c00224695.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
  • If this message persists, contact an HP-authorized service or support provider. Please let me know if this helps you!
  • 10/1/2011 5:49:55 AM • HP LaserJet 4600... • Answered on Oct 01, 2011
    Printing only symbols and numbers
    The two most typical causes for this type of behaviour are:
    1. wrong print driver being used. Ensure that you are either using the proper HP print driver for the 4600 or the HP Universal Print driver.
    2. Bad communication cable, loose connectors or dirty connectors.
    Try printing the configuration page from the control panel. If that prints ok then it is more likely the two above causes. If the configuration page prints wrong then you probalby have a formatter issue or memory issue.
    To print the configuration page, press the down arrow until it reads information, press the check mark, then use the down arrow until configuration page shows then press the check mark again.
    7/2/2011 1:26:32 AM • HP LaserJet 4600... • Answered on Jul 02, 2011
    My network laserjet 4600 only comes out black not
    http://h10039.www1.hp.com/cpso-support-new/pq/4600/home.html
    Try the above troubleshooting steps for each color page that prints out for test pages.
    Try to click on 'magenta' for instance, and follow the leads to a solution for your black only print problem.
    2/10/2011 6:11:40 PM • HP LaserJet 4600... • Answered on Feb 10, 2011
    HP LaserJet 4600 Printer Logo
    77 questions posted
    k24674
    Grand Canyon Tech
    Grand Canyon Tech
    View Most Popular
    LaserJet HP
    • LaserJet HP
    Most Popular Question
    printing only symbols numbers
    • Office Equipment & Supplies
