20 Most Recent
Apple Wireless Keyboard Questions & Answers
Last battery in my Mac wireless keyboard is
Usually a stuck battery is caused by a battery that has leaked acid in the battery compartment...If it a small space you might try a small dental mirror to see why it is stuck..
Since it is a keyboard a strong magnet like a mechanic uses might have enough force to pull it out...unfortunately some product are designed to be a pain in the backside so you have to resort to beating the xxxx out of it
How to set up a wireless keyboard?
Setting up a wireless keyboard can at first seem difficult, but with these steps you will see it is very simple.
Because the Keyboard is wireless...
1. You must find the power button located on the keyboard, and turn it on.
2. Insert the USB found with the product into one of the USB ports usually located on the sides or even the back of the computer.
3. A setup Assistant will appear after a few seconds, and simply follow it all the way through.
4. Enjoy typing from a distance!
How to replace a key
Go to the manufacturer website and put in your make and model and follow the instructions
Would like to see keyboard is connected on
If you'd like to check if it's connected, go into System Preferences, then Bluetooth. It will show you what devices are connected there.
There is also a checkmark box at the bottom of the window where you can choose to have the Bluetooth status show up next to the clock at the top of your screen.
Apple wireless keybaord function keys on top dont
Go to your system preferences. You go to the upper left hand corner click the apple and go to system preferences. Click the keyboard settings. Make sure that "Use all F1, F2, etc. as function keys is not checked off
It won't type anything.
Have you been using the keyboard up till now and has it been connected Via bluetooth. Be sure Bluetooth is turned on. Normally no or very few problems with this product.
F
Apple wireless keyboard. the keys
Sorry to read about your problem, I hope this helps you out.
your keyboard got wet by a drink..nothing you can do, except buy a new keyboard.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
