20 Most Recent
Canon imageCLASS D660 All-In-One Laser Printer Questions & Answers
Print quality
You certainly haven't been very specific! I assume you mean that your print quality is poor, and you would like it to be better.Assuming you're running Windows, click Start/Settings/Printers and Faxes, right-click on your printer, and select Properties.On the 'General' Tab, click Preferences. A new window should open which is directly related to your printer. Somewhere in that window should be a place to adjust the print quality.Good luck. Let me know if this fixes the problem.
Copies come out with dark
Looks like a dirty, scratched or contaminated drum. Try wiping the drum with a very soft cloth, the streaks should go away but may re-appear. If there are visible marks on the drum that cannot be wiped of with the cloth, the drum will have to be replaced. DO NOT TRY USING ANY SOLVENTS TO CLEAN THE DRUM.
How to remove jam paper from photocopy machine
Hi there remove the front cover & side cover there you can find the jam papers. Just pull the paper & start printing. After that if you face same problem then check the paper trey & then turn off the machine for 5 minute & try. after that let me know the result.
Paper jammed in Cannon D660
Typically this happens becuase the lower fuser roller (P# RF5-2601) is worn and makes the paper stick before it comes out - OR - the upper fuser film sleeve (P# FG6-7948-UFFS) is torn or worn out. Do not try poking something in there in an attempt to get paper out. You will just damage more stuff. The fuser unit (P# FG6-7947) needs to be removed and parts replaced within it to do it right.
you can find the same on Canons Website. Don't go for the exact model no. D600 series uses the same driver.
