20 Most Recent Canon imageCLASS D880 All-In-One Laser Printer Questions & Answers
4answers
I am unable to print pdf documents on my Image
Maybe your pdf is protected by print password, in this case, you have to use the pdf password remover to remove the print permission.Here is tutorial on how to remove it on windows:http://www.pdfpasswordremover-mac.com/pdf-password-remover.htmlutube.png You-Tube video "BNhsIalgVfk" placeholder (do not delete)utube.png
7/19/2019 6:56:42 AM • Canon imageCLASS... • Answered on Jul 19, 2019
2answers
Canon d-860
e0003
11/23/2018 6:53:53 AM • Canon imageCLASS... • Answered on Nov 23, 2018
A LINE GOES ALL THE WAY DOWN A PAGE ON ALL COPIES. HOW CAN I GET RID OF THE LINE?
check your printer caterage. either your waste full and needs to serviced or check your printer drum if it has any line on it.
2/10/2017 8:16:33 AM • Canon imageCLASS... • Answered on Feb 10, 2017
2answers
Copies and faxes double images how to solve
put an old or new toner cartridge in it to see if the double imaging goes away. If it is still there its the fuser. I can help you with that if you need supplies for the fuser. Steven 818-888-0006
9/16/2016 9:02:15 AM • Canon imageCLASS... • Answered on Sep 16, 2016
Adf does not feed
TRY TO RESET AND REPROGRAM THE ADF OR CLEAN THE FEED RUBBER
11/9/2014 3:38:12 PM • Canon imageCLASS... • Answered on Nov 09, 2014
Canon c2880 streak across width of 8 1/2 X 14 paper when printed
THE PAPER SELECT ARE NOT COMPATABLE, SELECT LGL IS EQUAL TO 8.5/14 FLSC IS EQUAL TO 8.5 /13. TRY TO SELECT BLACK COLOR OR CLEAN YOUR DEVELOPING UNIT.
11/9/2014 3:21:42 PM • Canon imageCLASS... • Answered on Nov 09, 2014
Beeping noise when copying
CLEAN THE FEED RUBBER OF YOUR ADF, OR THE SENSOR. OR REPROGRAM ADF
11/9/2014 2:58:43 PM • Canon imageCLASS... • Answered on Nov 09, 2014
2answers
LCD Message - System Error E000
THE FUSER HAS STOPPED WORKING(wont warm up) REPLACE FUSER
11/9/2014 2:47:09 PM • Canon imageCLASS... • Answered on Nov 09, 2014
I have a Canon D880. It will print from my pc fine, but when I make a copy, it has a light streak right down the center.
What you are referring to is the transfer roller. More than likely you will need to replace that item. Try BEST Office Products .
6/19/2013 9:30:51 PM • Canon imageCLASS... • Answered on Jun 19, 2013
3answers
What is error code E000 mean
Solution:
Press "Additional Functions",
Press "#", then press the "Right Arrow" button till it says, "Printer",
Then press "Set" then press the "Right Arrow" button again until it says "Printer Reset"
Then press "Set" again, the display will ask you "Yes" or "No".
Press the "Left" arrow for "Yes", then press "Set".
Now, unplug the power cord and wait 5 seconds and plug back in.
If this don't work, get a new fuser.
6/19/2013 9:24:56 PM • Canon imageCLASS... • Answered on Jun 19, 2013
2answers
Paper "accordians" just as it should be coming out of the printer
The fuser roll has little plastic pickoffs that guide the paper out. When a pickoff wears through the surface of the fuser roller, you get the issues you are having. Almost all the machines out there now have a fuser unit you can buy to replace the whole thing.
2/4/2013 4:46:39 PM • Canon imageCLASS... • Answered on Feb 04, 2013
3answers
Cannon image class D880 System Error E000
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
1/10/2013 7:49:57 PM • Canon imageCLASS... • Answered on Jan 10, 2013
Canon imageCLASS D880 All-In-One Laser Printer Logo
150 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
imageCLASS Canon
  • imageCLASS Canon
Most Popular Question
canon d 860
  • Office Equipment & Supplies
